Hi All,
Im new to smart home automation Sorry if questions will be ...... just start learning hubitat hub .
I have added couple devices like:
Fibaro smoke sensor , Aeotec MultiSensor 6, Aeotec Heavy Duty Smart Switch and more devices
Like Philips Hue I used Hue hub so no error there with lights
Now everything is working but when I checked logs I have errors
For Fibaro smoke sensor & Aeotec switch & multisensor I used driver code from internet because there is no code by default
I used code from github.com syepes Hubitat tree master Drivers
Multisensor
java lang Null Pointer Exception Cannot invoke method toInteger on null object on line 202
Fibaro
java lang Null Pointer Exception Cannot invoke method toInteger on null object on line 229
java lang.Null Pointer Exception Cannot set property 'lastbatt' on null object on line 360
My questions
Do I need to Ignore these error as when I add new device There need time to sync all config parameters etc ? or just ignore as everything looks like working
Or if driver code wrong ? and I need to get proper code ?
Just trying to understand errors If drivers code wrong so then maybe need to search forum for better drivers ??
Many thanks
