Hi all,
After a fair bit of head-scratching, I’ve ended up with a fully working, reliable Hubitat driver for the Sonoff MINI-ZB2GS-L (also sold as MINI-DUO-L).
This device can work well on Hubitat, but the sticking point is pairing. The relay is very sensitive to what the driver does during the Zigbee join process. If the driver is too “chatty” during join, Hubitat can silently leave the device half-joined, even though it appears in the UI.
This driver solves that by combining pairing-safe behaviour and full functionality in a single driver.
What this driver does
Pairing Safe Mode (default)
- Keeps the driver deliberately quiet during join
- Avoids child creation and heavy Zigbee traffic
- Allows the device to complete key exchange and endpoint discovery cleanly
- Prevents the slow-blinking “not really joined” state
Automatically unlocks full mode
- As soon as the driver sees a real device response (OnOff or Basic cluster)
- No manual driver switching required
Full functionality once paired
- Two child switches (Channel 1 and Channel 2)
- Parent switch is ON if either channel is ON
- Parent ON turns both channels ON
- Parent OFF turns both channels OFF
- Explicit Both On and Both Off commands
- Works like a typical dual-relay Z-Wave device
Manual escape hatch
- Includes a command:
unlockFullModeNow - Forces full mode if Hubitat does something odd during join
- Creates children and runs Configure in one step
Recommended pairing process
- Install this driver on your hub
- Put Hubitat into Zigbee pairing
- Reset the Sonoff (hold button during power-up until rapid blink)
- Let it pair using this driver
- Open the device page and hit Refresh once
The driver will automatically unlock full mode as soon as it sees a valid response.
If it ever looks stuck, run unlockFullModeNow once.
Tested behaviour
- Model: MINI-ZB2GS-L
- Endpoints: 0x01 and 0x02
- Standard OnOff cluster (0x0006)
- No manufacturer-specific commands required
- Stable on Hubitat once joined
Why this exists
The device itself isn’t broken. The issue is that Hubitat’s Zigbee join process is fragile when a driver sends too much traffic during pairing.
This driver explicitly works around that by separating pairing safety from normal operation, automatically.
Driver code###
Full driver code below ![]()
* Sonoff MINI-DUO-L, Dual Relay (Unified Pairing + Full Use)
* Pairing Safe Mode defaults ON for clean Zigbee joins on Hubitat.
* After first successful device response, driver unlocks full functionality.
* Manual escape hatch:
* - unlockFullModeNow: forces full mode, creates children, runs Configure
* Features in full mode:
* - Two child switches for endpoints 01 and 02
* - Parent switch is ON if either child is ON
* - Parent On turns both ON, Parent Off turns both OFF
* - Both On and Both Off commands
* Namespace: myhouse
* Author: ChatGPT & Mike Bradshaw
import hubitat.zigbee.zcl.DataType
import hubitat.device.HubAction
import hubitat.device.Protocol
metadata {
definition(
name: "Sonoff MINI-DUO-L, Dual Relay (Unified Pairing + Full Use)",
namespace: "myhouse",
author: "ChatGPT & Mike Bradshaw",
importUrl: "",
iconUrl: "https://raw.githubusercontent.com/hubitat/HubitatPublic/master/examples/images/zigbee.png",
iconX2Url: "https://raw.githubusercontent.com/hubitat/HubitatPublic/master/examples/images/zigbee@2x.png"
capability "Actuator"
capability "Configuration"
capability "Initialize"
capability "Refresh"
capability "Switch"
command "bothOn"
command "bothOff"
command "unlockFullModeNow"
fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006", outClusters: "0019"
fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008", outClusters: "0019"
preferences {
input name: "pairingSafeMode", type: "bool", title: "Pairing Safe Mode (leave on for joining, auto unlocks after first device response)", defaultValue: true
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable description text logging", defaultValue: true
input name: "createChildren", type: "bool", title: "Create child switches (Channel 1 and 2)", defaultValue: true
void installed() {
logInfo("Installed")
initialize()
void updated() {
logInfo("Updated")
if (logEnable) {
runIn(1800, "logsOff")
initialize()
void initialize() {
logInfo("Initialize")
if (isFullModeReady()) {
if (settings?.createChildren) {
createOrRepairChildren()
recomputeParentSwitch()
} else {
logInfo("Pairing Safe Mode active, keeping driver quiet until device responds")
void logsOff() {
device.updateSetting("logEnable", [value: "false", type: "bool"])
log.warn "Debug logging disabled"
/* -------------------------- Mode Logic -------------------------- */
private boolean isFullModeReady() {
if (settings?.pairingSafeMode == false) {
return true
return (state?.pairedOk == true)
private void markPairedOk(String reason) {
if (state?.pairedOk == true) {
return
state.pairedOk = true
logInfo("Device communication confirmed, enabling full mode, reason: ${reason}")
* Manual override in case Hubitat does something odd during join.
* This forces full mode and runs Configure.
void unlockFullModeNow() {
logInfo("Unlock Full Mode NOW requested (manual override)")
// Persistently disable safe mode so it stays unlocked
if (settings?.pairingSafeMode != false) {
device.updateSetting("pairingSafeMode", [value: "false", type: "bool"])
// Run configure to set reporting + read states
configure()
/* -------------------------- Parent Switch -------------------------- */
void on() {
if (!isFullModeReady()) {
logInfo("Pairing Safe Mode active, ignoring Parent ON to avoid breaking join")
return
logInfo("Parent ON (turns BOTH channels ON)")
bothOn()
void off() {
logInfo("Pairing Safe Mode active, ignoring Parent OFF to avoid breaking join")
return
logInfo("Parent OFF (turns BOTH channels OFF)")
bothOff()
void bothOn() {
logInfo("Pairing Safe Mode active, ignoring Both ON to avoid breaking join")
return
logInfo("Both ON requested")
List<String> cmds = []
cmds += buildOnOffCmds(true, 0x01)
cmds += buildOnOffCmds(true, 0x02)
sendZigbeeCommands(cmds)
void bothOff() {
logInfo("Pairing Safe Mode active, ignoring Both OFF to avoid breaking join")
return
logInfo("Both OFF requested")
cmds += buildOnOffCmds(false, 0x01)
cmds += buildOnOffCmds(false, 0x02)
/* -------------------------- Configure / Refresh -------------------------- */
void configure() {
logInfo("Pairing Safe Mode active, skipping Configure")
return
logInfo("Configure requested")
cmds += zigbee.configureReporting(0x0006, 0x0000, DataType.BOOLEAN, 0, 3600, null, [destEndpoint: 0x01])
cmds += zigbee.configureReporting(0x0006, 0x0000, DataType.BOOLEAN, 0, 3600, null, [destEndpoint: 0x02])
cmds += refreshCmds()
void refresh() {
logDebug("Refresh requested")
sendZigbeeCommands(refreshCmds())
private List<String> refreshCmds() {
cmds += zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x01])
cmds += zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x02])
cmds += zigbee.readAttribute(0x0000, 0x0004, [destEndpoint: 0x01])
cmds += zigbee.readAttribute(0x0000, 0x0005, [destEndpoint: 0x01])
return cmds
/* -------------------------- Child Devices -------------------------- */
void createOrRepairChildren() {
String parentDni = device.deviceNetworkId
String childDni1 = "${parentDni}-ep01"
String childDni2 = "${parentDni}-ep02"
if (getChildDevice(childDni1) == null) {
addChildDevice(
"hubitat",
"Generic Component Switch",
childDni1,
[name: "${device.displayName} CH1", label: "${device.displayName} CH1", isComponent: true]
logInfo("Created child switch CH1")
if (getChildDevice(childDni2) == null) {
addChildDevice(
"hubitat",
childDni2,
[name: "${device.displayName} CH2", label: "${device.displayName} CH2", isComponent: true]
logInfo("Created child switch CH2")
void componentOn(cd) {
logInfo("Pairing Safe Mode active, ignoring child ON to avoid breaking join")
return
Integer ep = endpointFromChildDni(cd?.deviceNetworkId)
if (ep == null) {
log.warn "componentOn: could not determine endpoint for child ${cd?.deviceNetworkId}"
return
logInfo("Child ON (${cd.deviceNetworkId}) -> endpoint 0x${hex2(ep)}")
sendZigbeeCommands(buildOnOffCmds(true, ep))
void componentOff(cd) {
logInfo("Pairing Safe Mode active, ignoring child OFF to avoid breaking join")
return
if (ep == null) {
log.warn "componentOff: could not determine endpoint for child ${cd?.deviceNetworkId}"
return
logInfo("Child OFF (${cd.deviceNetworkId}) -> endpoint 0x${hex2(ep)}")
sendZigbeeCommands(buildOnOffCmds(false, ep))
void componentRefresh(cd) {
if (ep == null) {
log.warn "componentRefresh: could not determine endpoint for child ${cd?.deviceNetworkId}"
return
logDebug("Child Refresh (${cd.deviceNetworkId}) -> endpoint 0x${hex2(ep)}")
cmds += zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: ep])
private Integer endpointFromChildDni(String dni) {
if (dni == null) return null
if (dni.endsWith("-ep01")) return 0x01
if (dni.endsWith("-ep02")) return 0x02
return null
/* -------------------------- Zigbee Command Building / Sending -------------------------- */
private List<String> buildOnOffCmds(boolean turnOn, int endpoint) {
int cmd = turnOn ? 0x01 : 0x00
cmds += zigbee.command(0x0006, cmd, [destEndpoint: endpoint], 0)
cmds += zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: endpoint])
return cmds
private void sendZigbeeCommands(List<String> cmds) {
if (cmds == null || cmds.isEmpty()) {
logDebug("sendZigbeeCommands: nothing to send")
return
cmds.each { String cmd ->
if (cmd != null && cmd.trim().length() > 0) {
HubAction action = new HubAction(cmd, Protocol.ZIGBEE)
sendHubCommand(action)
pauseExecution(60)
/* -------------------------- Parsing -------------------------- */
void parse(String description) {
if (logEnable) {
log.debug "parse: ${description}"
Map descMap = zigbee.parseDescriptionAsMap(description)
if (descMap == null || descMap.isEmpty()) return
if (descMap.clusterInt == 0x0006 && descMap.attrInt == 0x0000) {
markPairedOk("OnOff response")
handleOnOffAttribute(descMap)
return
if (descMap.clusterInt == 0x0000 && (descMap.attrInt == 0x0004 || descMap.attrInt == 0x0005)) {
markPairedOk("Basic identity response")
handleBasicIdentity(descMap)
return
if (descMap.clusterId != null && descMap.attrId != null) {
logDebug("ZCL: ep=${descMap.endpoint} cluster=${descMap.clusterId} attr=${descMap.attrId} value=${descMap.value}")
private void handleOnOffAttribute(Map descMap) {
String epHex = (descMap.endpoint ?: "").toString()
boolean isOn = (descMap.value == "01")
String eventValue = isOn ? "on" : "off"
if (txtEnable) {
log.info "${device.displayName} endpoint ${epHex} is ${eventValue}"
String childDni = null
if (epHex.equalsIgnoreCase("01")) childDni = "${device.deviceNetworkId}-ep01"
if (epHex.equalsIgnoreCase("02")) childDni = "${device.deviceNetworkId}-ep02"
if (childDni != null) {
def child = getChildDevice(childDni)
if (child != null) {
child.sendEvent(name: "switch", value: eventValue, descriptionText: "${child.displayName} is ${eventValue}")
if (isFullModeReady() && settings?.createChildren) {
} else {
if (epHex.equalsIgnoreCase("01")) {
sendEvent(name: "switch", value: eventValue, descriptionText: "${device.displayName} is ${eventValue}")
private void recomputeParentSwitch() {
def ch1 = getChildDevice("${device.deviceNetworkId}-ep01")
def ch2 = getChildDevice("${device.deviceNetworkId}-ep02")
String v1 = ch1?.currentValue("switch")?.toString()
String v2 = ch2?.currentValue("switch")?.toString()
boolean eitherOn = (v1 == "on") || (v2 == "on")
String newVal = eitherOn ? "on" : "off"
if (device.currentValue("switch")?.toString() != newVal) {
if (txtEnable) {
log.info "${device.displayName} parent is ${newVal} (derived from CH1=${v1}, CH2=${v2})"
sendEvent(name: "switch", value: newVal, descriptionText: "${device.displayName} is ${newVal}")
private void handleBasicIdentity(Map descMap) {
int attr = descMap.attrInt
String value = descMap.value
if (attr == 0x0004) logInfo("Manufacturer (raw): ${value}")
if (attr == 0x0005) logInfo("Model (raw): ${value}")
/* -------------------------- Logging Helpers -------------------------- */
private String hex2(int val) {
String s = Integer.toHexString(val).toUpperCase()
return s.padLeft(2, "0")
private void logInfo(String msg) {
log.info msg
private void logDebug(String msg) {
if (logEnable) log.debug msg
###END OF CODE###
Final notes
This has been running solidly once paired. Hopefully this saves others from the same trial-and-error.
