Hello friends, I have purchased a xiaomi plug, and when trying to link it with hubitat I realized that there is no controller for the plug, it is the ZNCZ07CM, I have another one, because if you see it, hubitat from xiaomi too, let's see if you can help me, thanks friends
I just Googled that model number, ZNCZ07CM, and it appears to be Bluetooth. If that is correct, this will definitely not pair to Hubitat because Hubitat does not (directly) support Bluetooth--only Z-Wave or Zigbee (some Xiaomi products like this are Zigbee), or supported LAN devices.
I have seen a couple people here integrate Xiaomi Gateway devices into Hubitat (assuming this can pair with their Gateway). There is also no easy way to do that, but you can put another system in between Hubitat and the Xiaomi Gateway to make it work: Apple Home (via HomeBridge for Hubitat), Home Assistant (with a community-supported Hubitat integration for Home Assistant and/or Home Assistant integrator for Hubitat), and likely other options I am not aware of. Unfortunately, none are as simple as just pairing the device to Hubitat, so I'd stick to known compatible devices (or more easily supported community options if you are OK with that, too) to avoid this in the future.
you're right, I just looked at it and it's BLE, my joy in a well
