Driver for Zigbee Tuya Power Monitoring
In your screenshot 2 posts above, the driver's version history (with version #s) should be directly below the section you posted.
So the version if I interpret correctly is 1.9.7. Package manager is grabbing this one. Can you please send me a link to go grab the raw driver and manually install it please? Thank you jj
Krassimir linked it for you above in post 34...
Updated to 2.0.0 and initialized but no change in the device. When I run the vacuum its a heck of a surge and the device sees nothing. .06 amps and never changes. I have another sensor of this type on the way. I'll wait and try it - perhaps it will work. Thank you all for the help jj
Is the device online to your hub?
What happens if you click on the Ping() command button? Do you see a rtt (round-trip time) numeric value in the Current States section, or you see a โ€˜timeoutโ€™ 10 seconds later?
it consistently is 80 or under, tried ping 5 times, instant answer back.
This means the device is online. If you enable the Debug logging, what is in the live logs? Any warning messages?
These devices are rather chatty, you should see longs every few seconds ...
How is the clamp installed? It should be placed over ONE of the wires (either the live or the neutral wires), but never both.
The last point is the issue I'll bet 10 bucks on it. It is clamped over the power cord that contains both hot and neutral. I will try and see. Thank you again for the help!
