Does anyone know of a driver for the Tuya Wireless Water Detector (model IH-K665)?
I thought I found one before buying, but now I cannot find it.
It's Zigbee, and it connects to Hubitat, but I cannot get it to report back when it's wet.
Did you try the HE inbuilt driver - most of the Tuya water leak sensors should work fine with it.
Assign the driver manually, then obligatory pair the device once again to the hub (without deleting it)
If it still doesn't work, you can try this custom driver - your device may be the same as in the link.
can you post the device data? I think I have 1 working but need the
Good find. Thanks. The generic driver works. I was looking for “leak” or “water”. I didn’t think to look under “moisture”.
What a relief. Thanks so much again for your help.
The generic driver worked, but I’m not sure if this data will changes anything:
I’m curious now as to what this means? What is an endpointId and application number?
If the generic driver didn't work, that info helps developers, like kkossev add the device to his custom drivers. Endpoint ID and application are specs in the Zigbee standard, much too complex to delve into here. Briefly, app 41 is home automation. Endpoint is sort of something that has a function or control. Some devices can have multiple endpoints, most only have 1.
