Driver for TS0601 _TZE200_pay2byax Tuya Zigbee window sesnor
Hi Guys,
I bought thr following window sensor.
Is there any generic driver I can use?
https://a.aliexpress.com/_mrapOiw
Nothing seems to work.
Hi @yanivsh23 ,
Tuya devices are not in Hubitat compatibility list, so the generic drivers may work, but may also not work. In the second case, you can always search this forum for "Tuya Contact Sensor" as an example.
If you copy and paste (as text) the device details 'Data' section I could probably help.
Thank you very much.
  • endpointId: 01
  • application: 45
  • manufacturer: _TZE200_pay2byax
  • model: TS0601
This is a rather non-standard device ...
Should be supported in this custom driver :
Works like a charm.
Thanks!
