Driver error (SmartSense Multi Sensor v4)
No. Nothing.
Error occurs ~45 minutes after device save which exceeds the 30 minute timer.
I don't have one of these, but was able to order one.
I take that back, i do have one, it was at the bottom of the ST pile of boxed devices...
But its not a V4, its a V5...
Can you get a picture of one of these?
I can get you a picture. I have some v5’s, but they do not generate any errors.
That's a 2016 version (v2?). While I have a bunch of them, most aren't in use as I find they go through the CR2450s far too quickly.
I do have one connected to a C-7 (for testing). I too am using the SmartSense Multi Sensor V4 driver. I don't see any errors from it in the logs, however.
well I have 2017 version of that device made in China, not Mexico. model STS-MLT-250.
I'll give it a shot and see what it does on a C8.
Did you figure it out?
Heck no, thanks for the poke, I have two NIB sts-mlt-250 units, factory reset multiple times and couldn't get them to join a C8 or a C7...
:frowning_face:
WTH
I didn't packet trace them, but its like they didn't bother channel scanning the active channels these hubs were using...
Never discovered...
I'll try again after things quiet down a little for me...
Any luck finding the error?
Thanks,
John
@mike.maxwell
Any progress?
If you share the code I can fix the error on my end.
@mike.maxwell
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 03:50:00.359 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)handleAcceleration: [raw:243301FC020810001800, dni:2433, endpoint:01, cluster:FC02, size:08, attrId:0010, encoding:18, command:0A, value:00, clusterInt:64514, attrInt:16]
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 03:50:00.356 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)parse: read attr - raw: 243301FC020810001800, dni: 2433, endpoint: 01, cluster: FC02, size: 08, attrId: 0010, encoding: 18, command: 0A, value: 00
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 03:49:54.407 PM[error](http://192.168.10.10/logs?tab=past&deviceId=286#)java.lang.NumberFormatException: signum-magnitude mismatch on line 310 (method parse)
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 03:49:54.372 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)handleAcceleration: [raw:243301FC02141200292E001400292C00, dni:2433, endpoint:01, cluster:FC02, size:14, attrId:0012, encoding:29, command:0A, value:002E, clusterInt:64514, attrInt:18, additionalAttrs:[[value:002C, encoding:29, attrId:0014, consumedBytes:5, attrInt:20]]]
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 03:49:54.369 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)parse: read attr - raw: 243301FC02141200292E001400292C00, dni: 2433, endpoint: 01, cluster: FC02, size: 14, attrId: 0012, encoding: 29, command: 0A, value: 2E001400292C00
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 02:49:59.334 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)handleAcceleration: [raw:243301FC020810001800, dni:2433, endpoint:01, cluster:FC02, size:08, attrId:0010, encoding:18, command:0A, value:00, clusterInt:64514, attrInt:16]
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 02:49:59.332 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)parse: read attr - raw: 243301FC020810001800, dni: 2433, endpoint: 01, cluster: FC02, size: 08, attrId: 0010, encoding: 18, command: 0A, value: 00
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 02:49:53.389 PM[error](http://192.168.10.10/logs?tab=past&deviceId=286#)java.lang.NumberFormatException: signum-magnitude mismatch on line 310 (method parse)
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 02:49:53.354 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)handleAcceleration: [raw:243301FC02141200292E001400292C00, dni:2433, endpoint:01, cluster:FC02, size:14, attrId:0012, encoding:29, command:0A, value:002E, clusterInt:64514, attrInt:18, additionalAttrs:[[value:002C, encoding:29, attrId:0014, consumedBytes:5, attrInt:20]]]
[dev:286](http://192.168.10.10/logs?tab=past&deviceId=286#)2023-07-28 02:49:53.350 PM[debug](http://192.168.10.10/logs?tab=past&deviceId=286#)parse: read attr - raw: 243301FC02141200292E001400292C00, dni: 2433, endpoint: 01, cluster: FC02, size: 14, attrId: 0012, encoding: 29, command: 0A, value: 2E001400292C00
Did you find anything?
Yes, it will be fixed in the first 2.3.6 release
