Double light Switch
Hi guys,
Im remodeling the laundry room and the last light switch I need to upgrade is this double light switch, the left turns on/off the laundry room and the right turns on/off the patio light outside.
Theres any smart switch I can buy that can give me 2 buttons like this one in the pic? Don’t need a dimmer, just on/off and I don’t t want to break the wall to make the gang box bigger, can be done?
Thanks a lot guys, stay safe!
I don't own one.
In the description, it says it works for two light switches in same gang box, not just a fan and light combo.
Depending on how much room you have in the box you could use a relay like this.
There are also a number of devices that work with the existing light switches (double).
It appears that the best supported is the AEOTec dual nano switch. (zwave plus). (hubitat driver)
Another alternative is the Enerwave RMS2-dual (zwave plus).
I believe that Zemismart also has a dual zigbee switch as well. (Not sure how supported that is).
I think this is the best and cheap solution
I use the Qubino Dual Relay also (Qubino Z-Wave Plus Flush 2 Relay) behind Legrand Adorne switches.
The challenge is getting it all to fit if the existing switches are already large... and the Adorne are. Makes it a challenge to stuff it all in.
Wiring is simple though.. take the load wires off the existing switch and stick them into the Load screws in Qubino. Then take a pair of small wires from the switches to the switch screws on the Qubino. Wire up the Line and Neutral on the Qubino and Bob's-your-Uncle.
