I have a couple Zigbee bulbs, one being an Osram RGBW that seems to give lots of people trouble. I think that if you provide lots of good repeaters, to a slight extent you might be able to overcome a couple bad repeaters in some cases.
But if you have a house full of these bad repeaters, pretty much nothing will drown them out.
So I would replace them as you can, get some good repeaters, and otherwise try to optomise things.
they do not need to be controlled individually. the 2 outside lights are directly connected to a switch that is always on. the basement lights always have power but are controlled through a smart switch.
It will probably be better to replace those two outside bulbs with a Zigbee (or even Zwave) switch. Cost-wise, and network-wise, I think that would be easier, cheaper, and better for the network than buying two smart bulbs.
I can do that. I do still have a Zwave switch that I used to have on my basement stairs. it was an older one and giving some issues, but I think it would work fine there since the bulbs are connected directly to the switch.... One thing though I almost forgot. I need the bulbs to always have power to them. I have a plugin adapter in one of the bulb sockets and I have a camera hooked to that. I don't really want to change it. This might impact using a smart switch there and not bulbs.
Ah, so a smart switch wouldn't be the best there. So stick with the Sengled that @ogiewon recommends above or something like the Inovelli Zwave bulbs.
As far as I know, most Zigbee bulbs either don't repeat (good) or are repeaters that mess things up. I am not sure if there are any good repeating bulbs?
Sengled bulbs are typically Zigbee, not Z-Wave. I don't think they make a Z-Wave bulb. They may make some WiFi bulbs these days, but I'd avoid those as well.
thanks I double checked what I ordered and they are zigbee. I was searching for zwave at the time and thought that is what I bought. I had not hooked them up yet so I didn't know.
WOW I removed the 4 GE bulbs and put the Sengled in their place. now the zigbee repeater is closer to the door lock than any other zigbee device. take a look at it now.
What’s the issue with Peanut plugs? I have 3 of them in my network, along with 3 Sengled bulbs, and they’ve worked great for the past 6 months (one of them controls the hot water recirculation pump, so is mission critical in our house). Conversely my 4 Ikea Tradfri outlets became unresponsive over their first few weeks and are now in the trash.
