Does anyone have a reliable door knock rule?
I had one in WebCore that only alerted if the door had been closed for x seconds/minutes AND the door sensor detected acceleration AND the door contact sensor remained closed for 3 seconds. Once matched, the rule would speak "Someone knocked on the xxxxx door".
I'm close with rule machine but get a lot of false positives from what I think is the door lock causing acceleration and not having (or finding) the ability to only trigger if the door has been in a closed state for x seconds/minutes prior to the rule triggering.
EDIT 4/1/2019 - See Post #12 for the full ruleset.
