I have a Dome Motion Sensor DMMS1 using the System driver. In my logs the sensor reports "Kitchen Motion Sensor motion is active" 13 times each time it senses motion, and 13 or 14 times when it goes inactive. Is this "normal" ?
I haven't noticed the with other devices.
abe normal
I'm seeing occasional duplicates, never 13
dev:3942018-11-18 11:39:44.217 am infoMultiSenDomeM (guestbath) illuminance is 105lx dev:3942018-11-18 11:09:43.287 am infoMultiSenDomeM (guestbath) motion is inactive dev:3942018-11-18 11:08:39.415 am infoMultiSenDomeM (guestbath) illuminance is 113lx dev:3942018-11-18 11:08:39.385 am infoMultiSenDomeM (guestbath) motion is active dev:3942018-11-18 11:08:30.502 am infoMultiSenDomeM (guestbath) illuminance is 111lx dev:3942018-11-18 11:08:30.463 am infoMultiSenDomeM (guestbath) motion is active dev:3942018-11-18 11:08:06.721 am infoMultiSenDomeM (guestbath) motion is active dev:3942018-11-18 10:09:54.376 am infoMultiSenDomeM (guestbath) illuminance is 2lx dev:3942018-11-18 09:39:55.457 am infoMultiSenDomeM (guestbath) motion is inactive dev:3942018-11-18 09:38:54.377 am infoMultiSenDomeM (guestbath) motion is active dev:3942018-11-18 09:38:45.373 am infoMultiSenDomeM (guestbath) illuminance is 107lx dev:3942018-11-18 09:38:45.294 am infoMultiSenDomeM (guestbath) motion is active dev:3942018-11-18 09:38:26.501 am infoMultiSenDomeM (guestbath) illuminance is 0lx
I'm using the native Dome Motion Sensor driver.
dev:1082018-11-18 15:09:11.715 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:11.342 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:11.316 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:11.172 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:11.118 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:11.064 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.861 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.834 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.795 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.744 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.721 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.697 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.661 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:09:10.551 infoKitchen Motion Sensor motion is inactive
dev:1082018-11-18 15:08:32.020 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.646 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.576 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.437 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.412 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.257 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.230 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.191 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.140 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.128 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.100 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:31.066 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:30.950 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.915 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.846 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.730 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.617 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.366 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.340 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.301 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.249 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.227 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.206 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:22.059 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:01.202 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:01.163 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:01.005 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.923 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.866 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.755 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.707 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.614 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.587 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.549 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.497 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.474 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.451 infoKitchen Motion Sensor motion is active
dev:1082018-11-18 15:08:00.321 infoKitchen Motion Sensor motion is active
I believe (and believed) you.
The question I was trying to help with was:
and I think, yes, it does output multiple, but that I hadn't seen 13... yet.. in 6 months.
It's cool, other than the reporting it seems to be operating satisfactorily.
I have one other dome motion that seems to report normally (one report per event).
When I get a chance I will try to remove and reinstall it, and see what happens
This would send false HSM alerts?
