EcoLink makes contact sensors with screw connections inside them for just this type application. No soldering just striping back the wires and screwing them into a terminal connection.
I was thinking about doing that with this, it has 2 screw terminals on the bottom and is a bit cheaper, 1 piece, no magnet etc...
This is a WIFI device so make sure there is a driver and it probably won't work if your internet is down.
@aaiyar do you think this would work? Zigbee mesh issues not withstanding Thank you
Tap water conducts electricity, so when this sensor gets immersed in water the two contacts will be connected and the sensor can send an alarm.
Itβs zigbee, a non standard zigbee
I'm using them here with no issue. Should I expect issues since it's non-standard Zigbee?
Is that the only issue? Or is it also harder to KEEP paired? I had no issues whatsoever pairing the Aquara water sensor, wet\dry testing worked fine and I've had no problem reports from it since. I get battery life etc.. Of course it's under a washer, so if it stops responding I'd never know...
they also sometimes drop off, but its usually an issue with repeaters. See this guide Xiaomi & Aqara Devices - Pairing & Keeping them connected
Could be bed sensor?
They said yes on the of thread
I have 4 of them and have not had any issue with them dropping off. It was a pain to pair some of them, and others just paired immediately.
The Ikea Zigbee repeaters work well with them. The Tuya Zigbee 3.0 repeaters are probably the best way to go.
OK sorry I just saw the first note on the page you linked to and it said it required a 2.4Ghz secure network, so I assumed it was WIFI.
