I do not consider this urgent, and documenting it would be just as good a solution as changing the code.
The uploadHubFile() method is not really documented at File Manager API | Hubitat Documentation nor at Common Methods | Hubitat Documentation . From those limited docs, it was not clear to me what limitations a file name has. Specifically, I got bit by user-input names sometimes failing without an error. Because they had spaces.
This is well documented at File Manager | Hubitat Documentation, but that is not linked from Common Methods | Hubitat Documentation and I didn't find File Manager API | Hubitat Documentation until writing this issue.
Please consider adding a link to the File Manager | Hubitat Documentation documentation as a pointer to file name limitations at the other two locations.
I would also request that uploadHubFile() be changed from a void to a boolean, so that we can at least find out that it failed. Or perhaps a String, with it removing illegal characters and returning the effective file name.
