I wanted a reading room, cinema room and family room. To put a projector in any of these rooms normally dominates the whole room. So I set about to build DIY system that hides the projector completely when not in use. I did not have the option of a roof space projector screen so I came up with a design that would hide it on top of a book case.
The whole build was relatively cheap, i.e I spent no more than £400 for the bookcases, screen and gear.
Please excuse the clock noise, I like it and it does not bother me when the film starts
Very nicely done! I liked how the lights automatically turned off in the bookcase as the screen was lowered.
Thanks for sharing!
Great job!
Very cool!
Really amazing!! Details please....
In particular, what gadgets did you use?
I'm particularly looking for a gang of relays, to do simple on off lighting, like five relays.
THAT, is awesome, love it!!
Thanks, you will probably not like the details as much.
I'm using a couple of zigbee (sonoff) relay switches. For the screen, it had it's own control box with a pendant control switch.
The pendant is a live, live, neutral for up and down so I cut the pendant off and wired it to a 240V DPDT relay which is then wired to a sonoff relay (the sonoff only switches live, so can only switch 240VAC not DC.)
The actuator to control the slides is 12VDC, I used the another DPDT relay and another sonoff.
The diagram shows this better, sorry for the non precise schematic, its late.
I think all the bits were like £30. I would like to put this down that each relay is insulated in separate plastic boxes.
For extra safety, I have all the power routed through a salus power plug. My program energises the salus and a second later all the automation of the relays happen, then after 3 minutes shuts the power off.
For feedback I have placed a zigbee contact sensor on the closed position to of the front panel and one on the screen, this ensures the program does not initiate to the next step until a sequence is complete. Even then I put in some serious delays in case something goes wrong.
I'm unsure if this fits your bill, I looked at fibaro and various other relay drivers. They all seem quite expensive for what they are, but then again I do get drop outs on the sonoff occasionally and have to pair them again.
@northan
Brilliant job!
What did you use for the linear actuator?
I think I got all my bits off Amazon.
Hang on, i will send links on the bits
https://www.amazon.co.uk/gp/product/B00BG61L6E/ref=ppx_yo_dt_b_asin_title_o09_s01?ie=UTF8&psc=1
https://www.amazon.co.uk/gp/product/B07DXS8DBJ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
The actuator is noisy, but what do you expect for £20 lol
