Iāve still got a stack of SCSI parts for PC and my old Macās. I knew theyād be worth having one day.
Thatās a good idea, this ups is costly enough.
Agreed, Iāll start one.
It really doesnāt need it.
New thread is live:
First round of design goals is here:
Could you consider light pipes into a top edge of the case so the status can be viewed from both the top or the side ??
Maybe little 2mm rectangular slots, up the side and 2mm across the top
Whoops shoulda jumped to the new thread
Hmmm. Have an ,mains/battery output for the power attribute?
We are thinking about it, we may go for a simpler solution as simple = lower cost,
So this is turned out to be a really nice unit. The casing itself is super solid. Orientation can be up or down and it doesn't have that big block look about it. I ran tests on it for a couple of days and the output is consistent. Packaging was amazing. Normally you get crap packaging with stuff like this but this was over 1/8th" thick cardboard box. Heavy. Will really dense packing foam. Available on amazon.
Did everyone get their USB UPSās?
My tracking shows at least half have been delivered, but sometimes itās inaccurate.
Mine got delivered and they are in use.
Mine hasn't arrived yet.
No worries, my tracking says itās still in transit.
You replaced it with a tasmanian devil didn't you?
I've got mine, thanks.
yep, got mine. thanks!
I'd be interested in one.
Derek - would the current units support a rpi3B?
Possibly, although they are kinda fussy if they donāt get 3 amps IME.
