Hi,
Wanted to use my existing motion sensors and door sensors to build an alarm system I could use with geofencing to automatically activate and managed to pickup a second hand Hive siren (sometimes called hive homeshield siren) for cheap.
It's ZigBee and managed to get it to connect to the hub but can't find a universal or driver which works with it.
It also has a bright led light which is useful and can be switched on and off if selected the dimmer driver but there is not a driver I have found which works with the siren sound
I can’t any other zigbee coordinator that the Hive siren uses. Do you know if it is ZHA1.2 or zigbee 3.0, which would be needed for it to work with Hubitat?
I can't find it as a zigbee 3.0 certified device. Also, the documentation you linked to indicates it was available earlier (perhaps 2017?). There's also no indication of ZHA1.2 or zigbee 3.0 compatibility - so I suspect it is using a proprietary zigbee profile.
