Any reason for not being able to display the background images stored on Google Drive? They do show up when stored local
As long as they’re able to be reached without restriction from the internet it shouldn’t be an issue, i.e. you’ll have to have a “shared” link to them
I do have a shared link. Can open in any browser but not in the dashboard Here's the link to image:
https://drive.google.com/file/d/11BSRPYJ1ResTSMgU4L169Tx2Kfv3TwiD/view?usp=sharing
The issue appears that it isn’t a true link to the image, but is a link to the image viewer. Did you share or publish?
Share
Image is stored on my Google Drive
Try publishing it to see if it is handled different or maybe the get link option.
Appears that the solution may be to use the Get Link option and then change open to uc
It worked.
Thank you
Use the </> to post the url if you don’t want it expanded…
