Dimming RGB up on motion
I have been trying to write a routine in RM that can set bulb color and dim up over a few seconds. The routine will not change the dimmer any more than what is set in the "set color" lines. I am trying to avoid having the light come on at full brightness instantly especially in the evening and night modes. I have tried adding delays around the "adjust" command but it has not worked. What am I not understanding?
Inovelli Bulb Multi-Color LZW42
Logs
I reset the "set color" commands to 100% until I figure how to make it dim up over seconds. Here is what that log looks like.
You could set the default fade time in the device preferences of Exercise Bulb to be the 2 seconds you want, and not worry about setting it in the rule.
Using "Set Color by Mode" is a nice concise way to set the color without having to build the conditional logic. I did a mockup of how that would look. It appeared you were raising the level to 100%, so I showed that, but you can set different levels for each mode too.
I tried that first but it does not allow for a gradual increase to 100%. The light instantly comes on to the level set. I tried setting to 1% when setting color and then using a command to increase dimmer to 100% over 3 seconds and that would not work. Turning off is the only time the device setting of dimming speed 3 seems to have an effect.
It sounds like there is a more fundamental issue at hand. What kind of color bulb or device is “Exercise Bulb”?
