Dimming Automation Recommendations
Hello!
Looking for recommendations on setting my recessed lights on a automatic dimming schedule. I have downloaded the Circadian Daylight app and while it seems to be doing a great job at changing temperature automatically it is not dimming lights at all. I am not sure if I have a setting wrong or what.
Recommendations greatly appreciated!
You could post screen shots of your settings in the Circadian app if you'd like help w/the settings for that app, assuming it supports dimming. Not clear from your post if the app is supposed to support dimming or not.
The Motion and Mode Lighting App should also be able to do what you want using modes...I haven't used it for that but the settings look like what you need:
I noticed you also posted in the Circadian Daylight thread yesterday - you might want to wait a bit for a response, likely the best help will come from other users of that app who are on that thread and experienced with it's idiosyncracies. Others w/no experience w/the app, like me, are going to be less help, obviously. I don't see anything obvious in your settings...Generally better to avoid double-posting on issues.
I was more looking for app recommendations other than the Circadian app as reading through that post it appears as though possibly thr dimming functionality is not working.
Then I would recommend you look at Motion and Mode lighting next. :slight_smile:
