@Madcodger - Are yours the Aeotec 6 or 7 model? If they are the 7 series then what firmware?
My prior observations on this topic include:
Also, the dedicated repeater has more freedom regarding antenna design, as they do not have to position it around relays, TRIACS, or other devices. No guarantees that anyone is doing good RF design or firmware implementation, though.
By "Dark Magic" you mean not at all magical....right?
Interesting, my experience does not follow the location relationship.
In my initial test of the Aeotec Extender 7 (firmware UNK)
I had some more distant devices pairing with a very old 300 series Leviton plug in dimmer. It was sitting on the floor under a table.
I unplugged the Leviton and replaced it with the Aeotec Extender 7.
Went back and checked the "more distant devices" and they paired with a Thermostat much further away than the Aeotec.
Hmmm.... Then I decided the distant devices might have paired before I plugged in the Aeotec.
OK I removed the Thermostat. The distant devices jumped to a dimmer (again further away than the Aeotec). This dimmer is in a metal wall box.
I tried a few other combinations and finally gave up. At least the dimmer was a Plus device.
I sent the Aeotec back to Amazon.
I would be nice if SiLabs documented route behavior. From what I've seen and read, it seems that route choice may add weight based on how long a route has existed (e.g. how long it's seen a neighbor). That makes some sense, better to have a route via a device which is consistently available than to bounce around between ones which come and go. That may also explain why people sometimes see it take weeks to settle down after a change.
Videos 8 and 9 touch on it a bit. Still not explicit full documentation of the base algorithms, weighting, tuning though.
It is one of those "all else being equal" things, while all else is never actually equal. Like you, I have an old Evolve LDM-15 plug-in lamp dimmer that is one of my most prolific routers. It is also huge, so it wouldn't surprise me if it had a proper dipole antenna in the thing.
I am not sure how much application-specific RF design goes on with smart home products. Probably minimal. So, your approach of returning the ones that don't work for you makes perfect sense.
“Any sufficiently advanced troublesome technology is indistinguishable from magic.”
A.C. Clarke - edited for relevance and clarity ![]()
I think my most quirky route situation is a device which has two repeaters on the path from the hub to it. However, another device uses this as its only hop to reach the hub. Clearly one of these two situations is nonsense, and perhaps both.
My actual "repeater" device is, ironically, one of the few devices in the house that didn't decide to go direct to the hub. It has two devices on the way to it, and nothing repeats through it.
That is consistent with my observations. I have 6 devices routing through a Leviton dimmer that was one of my earliest devices installed. This is in spite of the fact that I have numerous Aeotec and Ring range extenders scattered around the house that were added after the mesh was established.
Or, perhaps you just have a unique definition of "crappy" that is different than the z-wave spec.
If a route is "working", why change to something else that might fail? ![]()
Alternatively, if a device is experience many route changes searching for a good/stable connection, a new repeater at the right location will sometimes be picked up pretty quickly.
There's one case where a repeater is special, it will support smart locks and beaming. Not all z-wave plus devices support beaming.
I'm about 80% sure they're v6, and no idea as to firmware. I don't see either listed when I pull the device up on the hub from my iPad, which is what I'm currently using. Sorry.
I have been seeing this with the gen 7 not 6 so I guess that makes sense!
The older I get, the more I wish companies would just land on something that works reliably, and then stay there. But I'm a curmudgeon, so...
FYI I've been comparing nightly changes to my mesh (which had its last device installed 2 days ago). Here is what I observed. Note I have not used "repair" on any device.
If you have a device that is not used in any rules, nothing changes in the mesh for that device. Add one rule (like turn it off daily) and it becomes a device that the mesh actively changes.
The mesh tries hard to eliminate hops. I have one device that had 1 hop and was switched to direct despite a big drop in RSSI. Interestingly, I've seen this device toggle back to using hops like the algorithm is trying to find the best situation.
I've seen RSSI change for some devices like +/- 5DB from day to day. I don't know if this is mesh behavior or just random RF noise interference.
I found the same thing. I have two Aeotec Range Extender 7s and see them have very little impact on the mesh. A few days ago I unplugged one and it made zero difference - even on a device that has a speed of 9.6k.
How can you update the Aeotec Repeater? I thought Aeotec only had the updates embedded in .exe files and you had to figure out how to extract a .bin file from that? Will Aeotec send a .bin file?
I have a UZB-7 that I use as a secondary controller from time to time and can update using that + PC Controller Sw from SiLabs.. It's a very handy device to have. Can also use the Z-Stick (which is 500 series) or the Zooz S2 700 series stick.
EDIT: The system Firmware Updater app can also update using GBL files. I had to check.
Aeotec posts f/w gbl files for all their stuff on their support site. I've updated my RE7s a couple times using those files and the built-in HE firmware updater tool - updates went everytime (maybe slowly, but fine overall).
Most of my ZW devices connect direct to hub, but my RE7s route a couple things here & there - they're in locations that at least provide some peace-of-mind if I move other stuff around etc.
