So, I waited to see that others had luck first, then installed the latest update...so I thought. Now I cannot communicate with the hub. My network sees it, but I cannot connect via webpage or cell phone. Any secret tricks to trey, or do I wait until Monday for a reply from Tech Support?
Off topic but for some odd reason, that's the first time I've seen dotted-quad spelled out.. I love it and have concluded that I should use it for the rest of my life.
First of all, THANK YOU! for the (very fast) response! It is GREATLY appreciated! I did reserve the IP addy and when I log onto my router, it shows the hub is connected to this address. When OI tried to access the WEB UI, it told me the connection was refused...did not notice this before.
Does your hub have a fixed/reserved IP address? Yes.
Can you see it at portal.hubitat.com ? YES!!! Will not do anything else
until I hear back (I never thought to try this...)
I have a C7 Hub...but I'm fairly certain it has always been Blue (Unless I'm too damned old to remember correctly)? LOL I know the Smartthings Hub is green (Version 2 anyway).
And you hopefully will If you didn't do so already, you said you can reach the Diagnostic Tool, can you perform a Soft Reset, restoring one of the recent backups by following instructions in below document:
