This morning I noticed no rules were firing, I went into the hub and noticed on every device I no longer have any command tabs! (the on and off tabs for example on a light switch) I rebooted and still every device shows the same thing. This is really weird:
It is every single device on my hub. 30+ devices. Drivers range from the standard GE light switch drivers to custom drivers for the Zooz in line plug energy meter. I will contact Support by email right now.
I am on 2.2.7.121. I will update right now to .128...
The logs for devices like my weather station are updating data. No errors in the logs that I can see. It is just items with on/off capability that have no commands or in the case of my attic fan that I just checked out some commands but no on/off:
Oh shxx. it is extracting the update, and now applying update as I am writing this. Not sure if I can stop this or not . Dont think I can. I will try the soft reset using a database backup as soon as the hub finishes updating.
Just checked the hub after updating to .128. Now devices with on/off capability are now showing the correct command tabs. Examples from the two I gave earlier:
