deviceHealthCheck errors in log
Just doing a routine scan of my logs for errors and noticed this coming up regularly on one of my devices. I'm having trouble tracking down what might be causing it.
When I look under scheduled jobs for the device I see this:
I am not sure where that is coming from as I don't seem to have any apps that would be doing it. I also have another one of these devices with no errors and no device health check scheduled. I'm sure this is not a big deal but I'm curious what it is and if I can clean it up.
Guessing that you’ve changed drivers on this device at some point. Easiest thing to do would be to change the device type to Device and use the remove scheduled jobs command, and then change the device type back to what you’re using now.
Couldn't be easier, thank you!
