Device stuck in Z-Wave
I'm running Platform Version 2.3.5.113, Hardware Version Rev C-7.
I had a device that for some reason decided it wanted to forget the Z-Wave network completely.
I attempted a refresh / replace within the Z-Wave settings, attempting to put the device back into pairing mode, but Hubitat wouldn't ever trigger an add event in the replace window. I was not able to get replace to work correctly to rebind the device back to the device entry where it belonged.
I removed the device from the Devices tab, having to use Force Remove, but now the Z Wave Settings shows an entry that won't delete.
How can I remove the entry from the Z-Wave Settings screen? The remove button on it won't work!
Make sure the device is powered off. Shut down the hub from the settings menu, then unplug power to the hub (at the wall not the hub) for 5 mins. Power backup and attempt to remove again.
