Hubitat, for better or worse, lol.
When the generac is running on automatic during a utility outage, if the high heat sensor wire is interrupted, the generator will stop. If put back to normal, the gen will start. It's, like, the only non-latching alarm. Of course, load has to be shed, and with Generac, the smarts are in the generator, not the transfer switch.
My plan is to shed any possible significant load, which I don't have much of, progammatically with hubitat, along with any cool down and warm up periods. Also, use sensors like temperature, presence, etc, to start/stop gen.
When I do the shedding, I'll still have something like 250 watts of parasitic load, but I don't think the gen will have problems starting up with that loaded.
It's sad that the transfer switch can't get involved directly, but I haven't found a way around it, other than this.
Yes, it's flaky, I should probably try to 'harden' it somehow.
This'll only be for when I go away, maybe only in winter, which I don't do much of anyway, now.
