Please Add Enable/Disable Logging Preferences to the 'Device' driver:
Is this really a repeater? If so Zigbee? Z-wave? What brand/model?
There may be a driver for this instead of just using "Device".
Repeating occurs at the level of the radio. Turning on logging at the platform level will not display anything.
For device like that someone could just make a new device driver that doesn't log. It would take about 2 minutes since it doesn't actually have to do anything.
I don't think hubitat ever intended people to use "device" as a permanent driver choice...
Something is off. i have some of those repeaters. Nothing like that in the logs.
There is no data in either Current Status or State Variables on the Device page.
Here is the Data from the bottom of the page:
Preference Manager doesn't contain a Device entry.
How can I track down why this device is creating info Log entries?
It's because you're using the "Device" driver.
@aaiyar ...what driver are you using?
I think I'm using the Ikea Tradfri repeater driver.
"Device" is intended as a catchall driver, not one to use, and it logs because that might be useful in the case where no driver could be identified for a device.
Simply pick any other Zigbee driver, and you can turn off logging.
Pick what @aaiyar uses above.
