I upgraded my hub to 2.3.3.xxx when it came out and I had a lot of problems. Stable rules didn't work using motion triggers, the hub mode wasn't working, a handful of items. No big deal, I restored back to my previous version to 2.3.1.142. Everything was good again. I wasn't overlly worried as I didn't need to take advantage of new features and if I just wait a while these bug will get ironed out.
I tried a later version of 2.3.3.xxx and same thing. Now 2.3.3.138 seems like it works like it should and that's where I'm at. My question is while I was at the previous version I renamed some devices and installed an app or two and had a few rules I had made. Upgrading to the newer version for some reason lost them and I'm curious if there is a way to get it back. If I revert back to the previous version it will be there, but rolling forward it is lost. It's almost like the upgrade isn't done on the active version I'm sitting on and a different one is used (pre my rules, updates and apps).
Thanks ahead of time, I'm hopeful this makes sense and I don't need to go through the effort of screenshots and the whole bit. It's probably a horse a piece of redoing the work vs creating the documentation for the case above. If someone's run into this it may be something I need to do in a specific way I'm not aware of. Its a few hours work I'm trying to avoid.
