Device Limits Lutron Caseta
Previously I mentioned.
I have 30 Hue Bulbs
Approx 30 Recessed Led lights (non wifi)
I am going to probably need 15 Lutron Switch and Switch/Dimmers
And I will need a number of sensors (motion and contact) probably 20
So I am reading that Lutron Caseta only supports 50 devices.
Would my total be 30 Hue Bulbs + 30 Recessed led lights + 15 Lutron switches + 20 Sensors = 90 Devices.
Or is 1 lutron switch that controls 6 lights non wifi led light considered 1 device?
Since I won't use lutron caseta to directly integrate with my hue bulbs I assume if I flip the lutron lights off hubitat can trigger a hue action as well ie "turn off everyting" by flipping the lutron switch?
So I think I am answering my own question - when looking at Lutrons 50 device limit - we're talking 50 lutron devices.
This. The limit is specific to Lutron devices such as Picos and switches/dimmers and not Hue.
and keep in mind we do support multiple lutron caseta smart bridge pros. So you can bring all those into hubitat and interact with them. They just can't see each other directly in lutron world.
Ok cool so hubitat is the bridge for the bridges
I was debating Ra2. But caseta will b fine
make sure you focus on the PRO part :smiley: Lots of low priced non-pro bridges are out there, but you don't want them.
Energy Avenue out of Vegas has one of the best prices around for Lutron devices. @ogiewon recommended them in this community and several of us have purchased from them. They are an authorized Lutron dealer and my devices shipped directly from Lutron.
https://www.energyavenue.com/Lutron/L-BDGPRO2-WH
So I just thought if I connect my hue lights to HE I will have 30 devices of the 32 is that correct?
Not following, where did you see a reference to a limit of 32 zigbee devices?
I think that info may stem from me, and I failed to state that is a direct pairing limit, which does not account for repeaters. My apologies for the confusion.
which does not account for repeaters...
Oops! 0 for 2. Will fix that.
I guess i am going to have to test this but is it better to directly connect the hue bulbs to HE. Or connet to hue hub. I presume HE but doesnt it have less feature
2 posts were split to a new topic: Hue lights
