I have an old SmartThings Multi Sensor that I just noticed is reporting battery and temperature values every 2 minutes or so and has been for weeks or possibly months. When I look at the Usage Stats, it's number 6 in usage even thought the door it's attached to is rarely ever used. As far as I can tell no other device is doing this.
Is this normal? Is a device's reporting frequency configurable? I'm relatively new to HE and don't understand why this is happening or how to troubleshoot so any advice is appreciated.
Here's a very small snippet of the logs for the device:
dev:1932023-04-14 11:32:28.156 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:29:58.665 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:29:58.661 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:27:29.170 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:27:29.166 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:24:59.678 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:24:59.673 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:22:30.189 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:22:30.184 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:20:00.697 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:20:00.693 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:17:31.213 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:17:31.208 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:15:01.722 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:15:01.717 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:12:32.234 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:12:32.230 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:10:02.786 pm infoPatio Door to Garage is 52.53°°F
dev:1932023-04-14 11:10:02.781 pm infoPatio Door to Garage battery is 81%
dev:1932023-04-14 11:07:33.254 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:07:33.249 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:05:03.759 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:05:03.755 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 11:02:34.275 pm infoPatio Door to Garage is 52.70°°F
dev:1932023-04-14 11:02:34.269 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:58:58.504 pm infoPatio Door to Garage is 52.88°°F
dev:1932023-04-14 10:58:58.498 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:56:29.010 pm infoPatio Door to Garage is 52.88°°F
dev:1932023-04-14 10:56:29.005 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:53:59.534 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:53:59.520 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:51:30.018 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:51:30.013 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:49:00.527 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:49:00.521 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:46:31.017 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:46:31.012 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:44:01.543 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:44:01.531 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:41:32.010 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:41:32.005 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:39:02.512 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:39:02.507 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:36:33.016 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:36:33.011 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:34:03.511 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:34:03.505 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:31:34.038 pm infoPatio Door to Garage is 53.25°°F
dev:1932023-04-14 10:31:34.011 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:29:04.515 pm infoPatio Door to Garage is 53.06°°F
dev:1932023-04-14 10:29:04.510 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:26:35.018 pm infoPatio Door to Garage is 53.25°°F
dev:1932023-04-14 10:26:35.013 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:24:05.516 pm infoPatio Door to Garage is 53.25°°F
dev:1932023-04-14 10:24:05.512 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:21:36.017 pm infoPatio Door to Garage is 53.25°°F
dev:1932023-04-14 10:21:36.012 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:19:06.517 pm infoPatio Door to Garage is 53.25°°F
dev:1932023-04-14 10:19:06.512 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:16:37.018 pm infoPatio Door to Garage is 53.43°°F
dev:1932023-04-14 10:16:37.013 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:14:07.536 pm infoPatio Door to Garage is 53.43°°F
dev:1932023-04-14 10:14:07.518 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:11:38.035 pm infoPatio Door to Garage is 53.43°°F
dev:1932023-04-14 10:11:38.030 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:09:08.540 pm infoPatio Door to Garage is 53.25°°F
dev:1932023-04-14 10:09:08.535 pm infoPatio Door to Garage battery is 81%
dev:1932023-04-14 10:06:39.008 pm infoPatio Door to Garage is 53.43°°F
dev:1932023-04-14 10:06:39.002 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:04:09.560 pm infoPatio Door to Garage is 53.43°°F
dev:1932023-04-14 10:04:09.555 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 10:00:33.719 pm infoPatio Door to Garage is 53.60°°F
dev:1932023-04-14 10:00:33.714 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:58:04.245 pm infoPatio Door to Garage is 53.60°°F
dev:1932023-04-14 09:58:04.228 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:55:34.718 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:55:34.712 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:53:05.238 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:53:05.227 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:50:35.702 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:50:35.697 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:48:06.217 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:48:06.202 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:45:36.691 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:45:36.686 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:43:07.210 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:43:07.192 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:40:37.679 pm infoPatio Door to Garage is 53.78°°F
dev:1932023-04-14 09:40:37.674 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:38:08.199 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:38:08.183 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:35:38.658 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:35:38.651 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:33:09.161 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:33:09.151 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:30:39.633 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:30:39.628 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:28:10.137 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:28:10.131 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:25:40.613 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:25:40.608 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:23:11.126 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:23:11.111 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:20:41.597 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:20:41.592 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:18:12.091 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:18:12.086 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:15:42.590 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:15:42.585 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:13:13.083 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:13:13.073 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:10:43.570 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:10:43.566 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:08:14.088 pm infoPatio Door to Garage is 53.96°°F
dev:1932023-04-14 09:08:14.081 pm infoPatio Door to Garage battery is 81%
dev:1932023-04-14 09:05:44.545 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:05:44.540 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:03:11.044 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:03:11.038 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 09:00:41.534 pm infoPatio Door to Garage is 54.15°°F
dev:1932023-04-14 09:00:41.529 pm infoPatio Door to Garage battery is 78%
dev:1932023-04-14 08:58:12.025 pm infoPatio Door to Garage is 54.33°°F
