Device Information Viewer
I had a need today to view metadata about a bunch of Zigbee switches (48), particularly the firmware version info. So Claude and I whipped up this little app that shows, for selected devices, Current States, Device Data, and some Device Details. This works best for showing metadata from similar devices. The data is displayed as an HTML table and can be exported as a CSV file. I haven't tested all of the options, so consider this to be an EARLY beta app.
2026-01-25 UPDATE: ver. 1.1 makes each device name a hotlink to the corresponding device in Hubitat's devices page.
Example HTML table output:
 *  Device Information Viewer
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * NO copyright claimed, released to the public domain. Written by Claude under the direction of John Land
2026-01-24: Initial version
2026-01-25: Changed device names to hot links to the corresponding Hubitat device page
definition(
    name: "Device Information Viewer",
    namespace: "Ver. 1.1",
    author: "Custom",
    description: "View and export device current states, device data, and device details as HTML table or CSV",
    category: "Utility",
    iconUrl: "",
    iconX2Url: "",
    iconX3Url: ""
preferences {
    page(name: "mainPage")
    page(name: "viewData")
def mainPage() {
    dynamicPage(name: "mainPage", title: "", install: true, uninstall: true) {
        section("Device Selection", hideable: true, hidden: true) {
            input "selectedDevices", "capability.*", title: "Choose Devices", multiple: true, required: true
        section("Data to Include") {
            input "includeCurrentStates", "bool", title: "Include Current States (attributes)", defaultValue: true
            input "includeDeviceData", "bool", title: "Include Device Data", defaultValue: true
            input "includeDeviceDetails", "bool", title: "Include Device Details (metadata)", defaultValue: true
        section("Default Sort Options") {
            input "defaultSortColumn", "text", title: "Default Sort Column Name (leave blank for Device Name)", description: "Enter exact column name (e.g., 'roomName', 'switch', 'manufacturer')", required: false
            input "defaultSortDirection", "enum", title: "Default Sort Direction", options: ["asc": "Ascending ▲", "desc": "Descending ▼"], defaultValue: "asc"
        section("Export Options") {
            input "includeTimestamp", "bool", title: "Include timestamp in filename", defaultValue: true
            input "csvDelimiter", "enum", title: "CSV Delimiter", options: ["comma": "Comma (,)", "semicolon": "Semicolon (;)", "tab": "Tab"], defaultValue: "comma"
        section("View & Export") {
            href "viewData", title: "View Device Data", description: "Click to view all device data"
            paragraph "<i>Tip: Click any column header in the table to sort by that column.</i>"
        section("CSV Download") {
            paragraph "After installing this app, you can access the CSV export via:"
            paragraph "<b>Local URL:</b> http://[HUB-IP]:8080/local/[APP-ID]/csv"
            if (state.accessToken) {
                paragraph "<b>Cloud URL:</b> ${getFullApiServerUrl()}/csv?access_token=${state.accessToken}"
            input "enableCloud", "bool", title: "Enable Cloud Endpoint (allows external access)", defaultValue: false, submitOnChange: true
        section("Note") {
            paragraph "<i>Note: 'Create Time' and 'Last Update Time' shown in Hubitat's device details are not accessible through the app API and cannot be exported.</i>"
def viewData() {
    dynamicPage(name: "viewData", title: "", install: false, uninstall: false) {
        section {
            paragraph generateHtmlTable()
        section("Actions") {
            paragraph """
                <button onclick="copyTableToClipboard()">Copy Table as CSV</button>
                <button onclick="downloadSortedCsv()">Download CSV (current sort)</button>
                <script>
                function copyTableToClipboard() {
                    const csv = tableToCSV();
                    navigator.clipboard.writeText(csv).then(function() {
                        alert('CSV copied to clipboard!');
                    }, function() {
                        alert('Failed to copy CSV');
                function downloadSortedCsv() {
                    const blob = new Blob([csv], { type: 'text/csv' });
                    const url = window.URL.createObjectURL(blob);
                    const a = document.createElement('a');
                    a.href = url;
                    a.download = 'device_data_' + new Date().toISOString().slice(0,19).replace(/:/g,'-') + '.csv';
                    a.click();
                    window.URL.revokeObjectURL(url);
                function tableToCSV() {
                    const table = document.querySelector('table');
                    const rows = table.querySelectorAll('tr');
                    let csv = '';
                    rows.forEach(row => {
                        const cols = row.querySelectorAll('td, th');
                        const rowData = Array.from(cols).map(col => {
                            let text = col.textContent.trim();
                            // Escape quotes and wrap in quotes
                            text = text.replace(/"/g, '""');
                            return '"' + text + '"';
                        csv += rowData.join(',') + '\\n';
                    return csv;
                </script>
        section("CSV Preview") {
            paragraph "<pre style='background: #f5f5f5; padding: 10px; border-radius: 5px; overflow-x: auto;'>${generateCsv()}</pre>"
def installed() {
    log.debug "Installed with settings: ${settings}"
    initialize()
def updated() {
    log.debug "Updated with settings: ${settings}"
    unsubscribe()
    initialize()
def initialize() {
    if (enableCloud && !state.accessToken) {
        createAccessToken()
    } else if (!enableCloud && state.accessToken) {
        state.accessToken = null
def collectDeviceData() {
    def allColumns = [] as Set
    def deviceDataList = []
    selectedDevices?.each { device ->
        def deviceValues = [:]
        // Collect Device Details (metadata) first
        if (includeDeviceDetails) {
            try {
                // Last Activity
                try {
                    def lastActivity = device.lastActivity
                    if (lastActivity) {
                        deviceValues['detail.lastActivityAt'] = lastActivity.toString()
                        allColumns.add('detail.lastActivityAt')
                } catch (Exception e) {
                    log.debug "Could not get lastActivity: ${e.message}"
                // Controller Type
                try {
                    def controllerType = device.controllerType
                    if (controllerType) {
                        deviceValues['detail.controllerType'] = controllerType.toString()
                        allColumns.add('detail.controllerType')
                    log.debug "Could not get controllerType: ${e.message}"
                // Type Name
                try {
                    def typeName = device.typeName
                    if (typeName) {
                        deviceValues['detail.typeName'] = typeName.toString()
                        allColumns.add('detail.typeName')
                    log.debug "Could not get typeName: ${e.message}"
                // Device Network ID
                try {
                    def deviceNetworkId = device.deviceNetworkId
                    if (deviceNetworkId) {
                        deviceValues['detail.deviceNetworkId'] = deviceNetworkId.toString()
                        allColumns.add('detail.deviceNetworkId')
                    log.debug "Could not get deviceNetworkId: ${e.message}"
                // Room Name
                try {
                    def roomName = device.roomName
                    if (roomName) {
                        deviceValues['detail.roomName'] = roomName.toString()
                        allColumns.add('detail.roomName')
                    log.debug "Could not get roomName: ${e.message}"
                log.warn "Could not access details for device ${device.displayName}: ${e.message}"
        // Collect Device Data
        if (includeDeviceData) {
            try {
                def deviceDataMap = device.data
                if (deviceDataMap) {
                    deviceDataMap.each { key, value ->
                        def columnName = "data.${key}"
                        deviceValues[columnName] = value?.toString() ?: ""
                        allColumns.add(columnName)
                log.warn "Could not access data for device ${device.displayName}: ${e.message}"
        // Collect Current States (attributes)
        if (includeCurrentStates) {
            device.currentStates?.each { state ->
                def columnName = "state.${state.name}"
                deviceValues[columnName] = state.value?.toString() ?: ""
        deviceDataList.add([
            values: deviceValues
    // Sort devices by name (A-Z) by default
    deviceDataList.sort { a, b ->
        a.name.toLowerCase() <=> b.name.toLowerCase()
    // Convert to map with id as key (maintaining sort order)
    def deviceData = [:]
    deviceDataList.each { device ->
        deviceData[device.id] = device
    // Sort columns: device info first, then detail.*, then data.*, then state.*
    // Within each section, sort alphabetically (case-insensitive)
    def sortedColumns = allColumns.sort { a, b ->
        def aPrefix = a.tokenize('.')[0]
        def bPrefix = b.tokenize('.')[0]
        def prefixOrder = ['detail': 1, 'data': 2, 'state': 3]
        def aOrder = prefixOrder[aPrefix] ?: 4
        def bOrder = prefixOrder[bPrefix] ?: 4
        if (aOrder != bOrder) {
            return aOrder <=> bOrder
        } else {
            // Case-insensitive alphabetical sort within each section
            return a.toLowerCase() <=> b.toLowerCase()
    return [
        columns: sortedColumns,
        devices: deviceData
def getDisplayName(String columnName) {
    // Remove prefixes for display
    if (columnName.startsWith("detail.")) {
        return columnName.substring(7) // Remove "detail."
    } else if (columnName.startsWith("data.")) {
        return columnName.substring(5) // Remove "data."
    } else if (columnName.startsWith("state.")) {
        return columnName.substring(6) // Remove "state."
    return columnName
def getDefaultSortColumnIndex(columns) {
    // If no default sort column specified, use Device Name (index 0)
    if (!defaultSortColumn || defaultSortColumn.trim() == "") {
        return 0
    // Try to find the column by display name (without prefix)
    def targetColumn = defaultSortColumn.trim()
    def columnIndex = 2 // Start at 2 (0=Device Name, 1=Device ID)
    for (colName in columns) {
        def displayName = getDisplayName(colName)
        if (displayName.equalsIgnoreCase(targetColumn)) {
            return columnIndex
        columnIndex++
    // Also try matching with prefixes
    columnIndex = 2
        if (colName.equalsIgnoreCase(targetColumn) ||
            colName.equalsIgnoreCase("detail.${targetColumn}") ||
            colName.equalsIgnoreCase("data.${targetColumn}") ||
            colName.equalsIgnoreCase("state.${targetColumn}")) {
            return columnIndex
        columnIndex++
    // If not found, default to Device Name
    log.warn "Column '${targetColumn}' not found, defaulting to Device Name"
    return 0
def generateHtmlTable() {
    def data = collectDeviceData()
    def columns = data.columns
    def devices = data.devices
    // Determine default sort column index
    def defaultSortIndex = getDefaultSortColumnIndex(columns)
    def sortDir = defaultSortDirection ?: "asc"
    def html = """
        <style>
            table {
                border-collapse: collapse;
                width: 100%;
                margin: 10px 0;
                font-size: 11px;
            th, td {
                border: 1px solid #ddd;
                padding: 6px;
                text-align: left;
                white-space: nowrap;
            th {
                background-color: #4CAF50;
                color: white;
                position: sticky;
                top: 0;
                cursor: pointer;
                user-select: none;
            th:hover {
                background-color: #45a049;
            th.detail-col {
                background-color: #2196F3;
            th.detail-col:hover {
                background-color: #0b7dda;
            th.data-col {
                background-color: #FF9800;
            th.data-col:hover {
                background-color: #e68900;
            th.state-col {
            th.state-col:hover {
            th.sort-asc::after {
                content: ' ▲';
                font-size: 0.8em;
            th.sort-desc::after {
                content: ' ▼';
                font-size: 0.8em;
            tr:nth-child(even) {
                background-color: #f2f2f2;
            .scrollable {
                overflow-x: auto;
                max-width: 100%;
        </style>
        <div class="scrollable">
        <table id="deviceTable">
            <thead>
                <tr>
                    <th onclick="sortTable(0)">Device Name</th>
                    <th onclick="sortTable(1)">Device ID</th>
    // Add column headers
    def colIndex = 2
    columns.each { colName ->
        def colClass = ""
        if (colName.startsWith("detail.")) {
            colClass = "detail-col"
        } else if (colName.startsWith("data.")) {
            colClass = "data-col"
        } else if (colName.startsWith("state.")) {
            colClass = "state-col"
        html += "<th class='${colClass}' onclick='sortTable(${colIndex})'>${displayName}</th>"
        colIndex++
    html += """
                </tr>
            </thead>
            <tbody>
    // Add rows for each device
    devices.each { deviceId, deviceInfo ->
        html += """
                <tr>
                <td><b><a href='/device/edit/${deviceInfo.id}' target='_blank' style='color: inherit; text-decoration: none;'>${deviceInfo.name}</a></b></td>
                <td>${deviceInfo.id}</td>
        // Add cells for each column
            def value = deviceInfo.values[colName] ?: ""
            html += "<td>${value}</td>"
        html += "</tr>"
    html += """
            </tbody>
        </table>
        </div>
        <script>
        let sortDirections = {${defaultSortIndex}: '${sortDir}'}; // Initialize with default sort
        function sortTable(columnIndex) {
            const table = document.getElementById('deviceTable');
            const tbody = table.querySelector('tbody');
            const rows = Array.from(tbody.querySelectorAll('tr'));
            const headers = table.querySelectorAll('th');
            // Determine sort direction
            const currentDirection = sortDirections[columnIndex] || 'asc';
            const newDirection = currentDirection === 'asc' ? 'desc' : 'asc';
            sortDirections[columnIndex] = newDirection;
            // Remove sort indicators from all headers
            headers.forEach(header => {
                header.classList.remove('sort-asc', 'sort-desc');
            // Add sort indicator to current header
            headers[columnIndex].classList.add('sort-' + newDirection);
            // Sort rows
            rows.sort((a, b) => {
                const aCell = a.querySelectorAll('td')[columnIndex];
                const bCell = b.querySelectorAll('td')[columnIndex];
                const aText = aCell ? aCell.textContent.trim() : '';
                const bText = bCell ? bCell.textContent.trim() : '';
                // Try to parse as numbers for numeric sorting
                const aNum = parseFloat(aText.replace(/[^0-9.-]/g, ''));
                const bNum = parseFloat(bText.replace(/[^0-9.-]/g, ''));
                let comparison = 0;
                if (!isNaN(aNum) && !isNaN(bNum)) {
                    // Numeric comparison
                    comparison = aNum - bNum;
                } else {
                    // String comparison (case-insensitive)
                    comparison = aText.toLowerCase().localeCompare(bText.toLowerCase());
                return newDirection === 'asc' ? comparison : -comparison;
            // Re-append sorted rows
            rows.forEach(row => tbody.appendChild(row));
        // Apply default sort on page load
        (function() {
            sortTable(${defaultSortIndex});
        </script>
    return html
def generateCsv() {
    def delimiter = getDelimiter()
    // Header row
    def csv = "\"Device Name\"${delimiter}\"Device ID\""
        csv += "${delimiter}\"${displayName}\""
    csv += "\n"
    // Data rows (already sorted by device name from collectDeviceData)
        csv += "\"${deviceInfo.name}\"${delimiter}${deviceInfo.id}"
            csv += "${delimiter}\"${value}\""
        csv += "\n"
    return csv
def getDelimiter() {
    switch(csvDelimiter) {
        case "semicolon":
            return ";"
        case "tab":
            return "\t"
        default:
            return ","
def getFilename() {
    def timestamp = includeTimestamp ? "_${new Date().format('yyyyMMdd_HHmmss')}" : ""
    return "device_data${timestamp}.csv"
// Mappings for endpoints
mappings {
    path("/csv") {
        action: [GET: "downloadCsv"]
def downloadCsv() {
    def csv = generateCsv()
    def filename = getFilename()
    render(
        contentType: "text/csv",
        data: csv,
        headers: ["Content-Disposition": "attachment; filename=\"${filename}\""]
