Device Firmware Updater - Zooz water sensor
So I followed the instructions from the Device Firmware Updater instructions.
I found the gbl file directly from Zooz support page and uploaded it to the hub via updater app. When I select Back after successfully updating, there's no option to Update Z-Wave Firmware. The only option is the Firmware File Manager. Am I missing a step?
What hub model (hardware revision) are you running? Check Settings > Hub Details or the bottom of your hub if you don't know. This only works on C-7 or later.
@bertabcd1234, I have a C-5. I had no idea it only works on C-7 or later. That's not on the instruction page. Do you know if there's another way to do it?
:thinking:
Yes, you could use the custom driver approach instead:
Here is a guide for using the driver updater
