Is there a dashboard feature (any of the various dashboard apps), that can list the most recent events of a device?
For example, I want to see a list of motion events by date/time.
in ClassicDashboard, click the 3 dots, top right. then click History, top right.
Of course, you have to have enabled those dots... Gear icon, top right, Options:
don't hide 'm
Thank you. Is there a way that I can see this as a table/tile without having to click into tile history?
I don't really want to click on a switch to turn on/off. I want to see the history of the switch being turned on/off (activated). It's actually a relay switch (the switch is activated by another device).
Only if you make something yourself. A custom device that gets fed the events could save them into an array, and then format the events into an attribute tile using html, and that could be displayed on the dashboard. Probably not the answer you wanted. You would need to keep list to a certain length, and drop the old entries as new ones come in, and rebuild the attribute table every time there is a new event.
Its been done before.
@jas23 check this thread: Looking for way to push notifications to dashboard tile - #9 by thebearmay
