Before the UI change I used to be able to ask for parameters without any parameter number, the Logs would show all the parameters the device responded to.
Is this still possible? Currently the "RUN" command is greyed out.
This was never possible from the "Device" driver and isn't related to the UI changes.
You must be thinking of something else, like the Basic Z-Wave Tool, which does have such a feature (though I would use with care since it requires iterating through all possible 256 parameter numbers it checks for if you don't supply one yourself).
If you're just curious and the device is Z-Wave Plus, one of the "Generic Z-Wave DT" drivers will read this information as supplied by the device (showing them under Preferences after) and might be an alternative you could consider, as well.
