@michael.l.nelson
Michael, I hope you donāt mind, I changed the thread topic to something more appropriate as I want to include switches and what we are actually doing is resetting them to put them into pairing mode rather than joining them.
Iām also trying to attract some switch suggestions
The 1st version of the app is almost ready and I will release it in the morning (if real life doesnāt get in the way)
Andy
@Cobra Zooz light switches are 3 quick ups. I would assume they are all the same whether a toggle or a paddle. If @agnes.zooz sees this she can probably chime in on all the rest of theirs.
I never thought of up/down..
I suppose a number of light switches would use this?
Currently, the app only does on/off but I could write a section for up/down
I assume the commands are:
device.up() and device.down()
Andy
Iām thinking of calling the app āDevice Reset Toolā which is the best Iāve come up with so far.
Can I have some suggestions please?
There must be something better!
Andy
But surely this requires physical access to the switch, right? Soft on/off commands shouldn't be able to reset it like a physical tap would...I hope. (We are talking about the hardwired switches, right?)
True. These are always timed power cuts that are required.
But for the switches, it isn't even power cuts--it's specific button taps. This is different from bulbs where an actual power cut is how the reset is performed and it could work well with, say, a bulb in a lamp that is connected to a smart switch (from which the cuts would be executed). Even if you were to somehow wire a hardwired light switch in this way, I don't see how it could work.
EDIT: I see now that this is maybe exactly what you meant.
Guys, are you saying that if the switch was wired up to an outlet and toggled the correct sequence this wouldnāt work as they need to be physical up/down presses?
If so, that has just saved me a bunch of coding
Andy
@Cobra I just got this off their manual for Zooz. I had it a bit off.
"If your primary controller is missing or inoperable, you may need to reset the device to factory settings. To complete the reset process manually, toggle-toggle-toggleānāhold down for at least 10 seconds."
Sounds like it needs to be physical.
Yes. But I thought you were just talking about resetting bulbs. I missed the bit where this changed to switches. Those almost always need a button press. Bulbs would work if you have an outlet that can react very fast, but some bulbs need a 0.5 second pause. Not sure you would be able to reliably achieve that in the needed sequences.
I honestly had not thought about the speed of the outlet switching.
Iāve been testing with virtual switches to confirm the sequences, but will try a couple of outlets tomorrow.
I have an ikea outlet and a smartthings one I can test with.
I find the IKEA a bit slow. No surprise given the price.
I'm not saying there aren't any out there that might work that way, but, yes, I think your interpretation is correct. (And in my opinion, this wouldn't be a huge loss, anyway--switches are generally much easier to reset that bulbs, many of which are dependent on specific timing...though the hardest part with either is sometimes remembering what the sequence actually is!)
This is the idea for this app.
You wonāt need to remember the sequence as the app should be able to do it for you.
(Assuming the outlet is fast enough!)
Andy
How about Forget About Remembering Tool or F.A.R.T.
I guess the switches will need to be tested to see which ones are reliable enough. I use Leviton z-wave switches. When I set them to flash they flip pretty fast. It has a default of 750ms which seems fast enough for most bulbs.
I have actually coded some for 500ms but that could be changed if necessary.
I have a couple of spare Fibaro switches here too I will probably test one to do the switching tomorrow to see how fast they are.
There seems to be only a couple of bulbs that require really fast switching anyway.
Most seem to be in the region of 3-5 seconds.
Anyway, itās past 1.00am here so time for bed for me
Iāll let you guys know tomorrow how I get on (and will probably release the app in the morning so you huys can have a play too)
@stephack
Not sure about your name suggestion
Andy
