I've noticed a Dome Leak Detector on a C5 is burning the battery at a fairly high rate so I suspect the detector is running S0. My C7 clearly shows the Z-Wave security settings but I'm not seeing that info on the C5. Is there a quick way to determine the detector's Z-Wave security setting from the C5's screens?
I can take a stick and laptop to the C5's location but would prefer to avoid the trip if possible. Thanks.
The only type of Z-Wave security pairing that the C-5 can do is S0. What does your device page show? Does the device page show that it is paired securely? If so, it’s S0. The choice is S0 or no security.
The Secure Join selector chooses how devices are joined when included. This screenshot is from my C-5 (now idle, all devices moved to my C-7). Can you show the bottom screenshot from the leak detector’s device page?
@ 672southmain - Good one. I never noticed the Secure Join box.
@ 672southmain & @JasonJoel - zwaveSecurePairingComplete is missing. So that's good. @aaiyar - I looked through those and didn't see any hits.
So I guess it's paired correctly and just has an apatite for batteries... I'll keep an eye on it and see how it goes.
It could also be a distance thing. If it has to transmit a ways to get to the next hop it can decrease battery life. Put a repeater in the area (like an aeotec) then do a z-wave repair and see if it improves
Good thinking. This is an new installation of my old C5 in a small townhouse. All of the mains powered Z-Wave devices are on the 1st floor; the leak detector is the only device on the 2nd floor, I plan to install another switch on the 2nd floor within arm's reach. That will be interesting to see if it makes a difference with battery life.
Here's the end of the story for the archives re the Dome Leak Detector battery saga.
With five new Z-Wave devices on the 1st floor running solidly for about three weeks, the one lonely Z-Wave leak detector upstairs has settled down to a steady 86% battery level. My guess is the battery was getting consumed as each new switch came online downstairs and the mesh sorted itself out. Everything is working as expected now.
