This topic was discussed here...
https://community.hubitat.com/t/utility-power-restoration-notification-for-when-on-generator/133556
...but was closed due to inactivity.
I have the same problem, but maybe a little worse becuase my load center is on an outside wall and the devices like the Briidea and PowerBack are "indoor only".
The portable generator is connected to the house load center via a power inlet receptacle hanging off the load center and an interlock kit.
When on portable generator power, my HE, security system (Elk M1G), network, and Internet access will all be on powered circuits (and UPS's), so they will "always" be up.
As the OP on the other topic stated, I'm looking for some way to close a relay when the power restoration device sees the utility power restored. I can wire the relay to a M1G zone to detect utility power restoration, and the rest is easy.
Anyone know if the main components for the commercial power restoration devices are publicly available, i.e., the components that sense power and do whatever it takes to power/sound the alarm (which should be enough power a relay closure)?
