Here you go!
dev:72020-08-05 09:26:58.764 infoTurning OFF relay 2 (endpoint: 3)
dev:72020-08-05 09:26:58.760 infoOn/Off Button press - description:read attr - raw: 7E07030006160000100000F02330000007, dni: 7E07, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 0000F02330000007 | parseMap:[raw:7E07030006160000100000F02330000007, dni:7E07, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:07000030, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]], valueParsed:false]
dev:72020-08-05 09:26:58.693 errorjava.lang.NullPointerException: Cannot invoke method parse() on null object on line 643 (parse)
dev:72020-08-05 09:26:58.674 infoPower Cluster 0006 catchall - description:catchall: 0104 0006 03 01 0040 00 7E07 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 7E07 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:7E07, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:72020-08-05 09:26:58.434 debugsendZigbeeCommands(cmd=[he cmd 0x7E07 0x03 0x0006 0x00 {}, delay 200])
dev:72020-08-05 09:26:58.428 debugcomponentOff() from 7-2
dev:72020-08-05 09:26:55.005 infoTurning ON relay 2 (endpoint: 3)
dev:72020-08-05 09:26:55.001 infoOn/Off Button press - description:read attr - raw: 7E07030006160000100100F0232F000007, dni: 7E07, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 0100F0232F000007 | parseMap:[raw:7E07030006160000100100F0232F000007, dni:7E07, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0700002F, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]], valueParsed:true]
dev:72020-08-05 09:26:54.950 errorjava.lang.NullPointerException: Cannot invoke method parse() on null object on line 641 (parse)
dev:72020-08-05 09:26:54.931 infoPower Cluster 0006 catchall - description:catchall: 0104 0006 03 01 0040 00 7E07 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 7E07 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:7E07, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:72020-08-05 09:26:54.625 debugsendZigbeeCommands(cmd=[he cmd 0x7E07 0x03 0x0006 0x01 {}, delay 200])
dev:72020-08-05 09:26:54.618 debugcomponentOn() from 7-2
dev:72020-08-05 09:26:50.328 infoTurning OFF relay 1 (endpoint: 2)
dev:72020-08-05 09:26:50.324 infoOn/Off Button press - description:read attr - raw: 7E07020006160000100000F0232E000007, dni: 7E07, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 0000F0232E000007 | parseMap:[raw:7E07020006160000100000F0232E000007, dni:7E07, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0700002E, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]], valueParsed:false]
dev:72020-08-05 09:26:50.222 infoPower Cluster 0006 catchall - description:catchall: 0104 0006 02 01 0040 00 7E07 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 7E07 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:7E07, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:72020-08-05 09:26:49.834 debugsendZigbeeCommands(cmd=[he cmd 0x7E07 0x02 0x0006 0x00 {}, delay 200])
dev:72020-08-05 09:26:49.826 debugcomponentOff() from 7-1
dev:72020-08-05 09:26:45.546 infoTurning ON relay 1 (endpoint: 2)
dev:72020-08-05 09:26:45.537 infoOn/Off Button press - description:read attr - raw: 7E07020006160000100100F0232D000007, dni: 7E07, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 0100F0232D000007 | parseMap:[raw:7E07020006160000100100F0232D000007, dni:7E07, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0700002D, encoding:23, attrId:F000, consumedBytes:7, attrInt:61440]], valueParsed:true]
dev:72020-08-05 09:26:45.413 infoPower Cluster 0006 catchall - description:catchall: 0104 0006 02 01 0040 00 7E07 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 7E07 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:7E07, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:72020-08-05 09:26:45.127 debugsendZigbeeCommands(cmd=[he cmd 0x7E07 0x02 0x0006 0x01 {}, delay 200])
dev:72020-08-05 09:26:45.119 debugcomponentOn() from 7-1
dev:72020-08-05 09:26:31.921 debugdirty model = lumi.ctrl_neutral2, clean model=lumi.ctrl_neutral2
dev:72020-08-05 09:26:31.917 debugModel Name Received - description:read attr - raw: 7E070100002E050042126C756D692E6374726C5F6E65757472616C32, dni: 7E07, endpoint: 01, cluster: 0000, size: 2E, attrId: 0005, encoding: 42, command: 01, value: 126C756D692E6374726C5F6E65757472616C32 | parseMap:[raw:7E070100002E050042126C756D692E6374726C5F6E65757472616C32, dni:7E07, endpoint:01, cluster:0000, size:2E, attrId:0005, encoding:42, command:01, value:lumi.ctrl_neutral2, clusterInt:0, attrInt:5]
dev:72020-08-05 09:26:29.259 debugsendZigbeeCommands(cmd=[he raw 0x7E07 1 0x01 0x0000 {10 00 00 05 00}, delay 2000])
dev:72020-08-05 09:26:29.255 debugrefresh cmd: [he raw 0x7E07 1 0x01 0x0000 {10 00 00 05 00}, delay 2000]
dev:72020-08-05 09:26:29.249 debugsendZigbeeCommands(cmd=[he raw 0x7E07 1 0x01 0x0000 {10 00 00 04 00}, delay 2000])
dev:72020-08-05 09:26:29.244 infoping()
dev:72020-08-05 09:26:29.194 infoDo nothing - The device already exists
dev:72020-08-05 09:26:29.181 infoMaking device with type 1 virtual switch and id 7-1
dev:72020-08-05 09:26:29.178 infoDo nothing - The device already exists
dev:72020-08-05 09:26:29.159 infoMaking device with type 1 virtual switch and id 7-2
dev:72020-08-05 09:26:29.146 debugdirty model = lumi.ctrl_neutral2, clean model=lumi.ctrl_neutral2
dev:72020-08-05 09:26:29.121 debugsendZigbeeCommands(cmd=[he raw 0x7E07 1 0x01 0x0000 {10 00 00 04 00}, delay 2000])
dev:72020-08-05 09:26:29.112 debugrecoveryMode: Slow
dev:72020-08-05 09:26:29.057 infoRecovery feature ENABLED
dev:72020-08-05 09:26:29.053 debugstartCheckEventInterval()
dev:72020-08-05 09:26:28.959 infogetDriverVersion() = v0.8.2.0803b
dev:72020-08-05 09:26:28.954 debugrefresh() model='lumi.ctrl_neutral2'
dev:72020-08-05 09:26:28.949 infoupdated()
