Nope, every attribute available is pulled from WDG. After doing a bunch of research I learned a lot about Heat Index, Windchill and Feels like.
First 'Feels Like' is a patented calculation by AcuRite.
As for Heat Index and Windchill. They are pulled from WDG if available (that's up to the station chosen). Both have their own set of temp/RH requirements to have this value valid. So you will only see one of the two with a value at a time (again, if available).
For me right now...
Temp: 44
RH: 57.65
Heat Index: No Data
Wind Chill: No Data
Although they are No Data right now, I have seen data in one or the other at different time.
BTW, I happen to have an AcuRite weather station...
Temp: 47
RH: 57
'Feels Like' is 37
Appreciate the information. Dark sky had it also, but the government wouldn't have it if it is patented (license$). Here it is 58 with a high of 73 (10:30am Georgia).
I have a question on how I actually get the data to populate in a dashboard, If I go to devices then the Tile i created for weather I see the weather data. Then I create a dashboard under device I select that Tile that gets that receives the data and Template I have tried selecting Weather, Image but the weather info never populates
Thank you sir, I appreciate it. I was able to get it added. I didnt realize that the actual instructions for using it were in docs as well I thought that docs were only the install instructions.
Thanks, I also see warnWeather Dot Gov - Connection to weather.gov API timed out. This is NOT an issue with this app, the website is simply busy. Try again later.
One quirk, not sure if it’s me/app/website, but I’m getting null for today’s pollen type, (yesterday’s and tomorrow work fine). Seen this a few days in a row now. Not sure how to show a log, if it is even helpful?
After I updated to version 1.1.4 of the Child app (via HPM) I'm getting below error on both of my child instances (I'm still on hub firmware version 2.2.0.128 - updating to 132 as I write this:
@bptworld what do I need to do to get rid of this error. app:32020-05-25 10:33:43.804 am warnExcluded attribute forecastTable1 size of attribute > 1024 characters
