Looking at the location of your 'menu' icon, you're probably using Smartly, I use it too. I've talked to @spelcheck about it and I put in place the adjustments they wanted/needed. Now waiting for him to put in the fix on the Smartly side.
BTW, the tile works perfect within a 'normal' dashboard.
For anyone else who relies on a field that returns "no data", I have set a variable and check against the last known good temperature to get around the weather.gov website being unavailable. Now my thermostat is more stable at setting itself relative to the outside temperature.
Thank you very much @bptworld for your diligence and hard work.
OK, It is once again probably something I am doing wrong, I just installed Weather Dot Gov and I am having an issue getting the Current data tile to display. The tile device shows the data, but I do not see an attribute listed in the Attribute Template. Am I using the correct template? All other states from the tile device seem to appear in the list, but not currentDataTile. I have deleted and reloaded the app and devices.
so my guess is this is some strange interaction with smartly any ideas on how to adjust vertical size so I dont have scroll bars right now I end up with a large blank area if I scale the button till the scroll bar disappears
Updated Tile Driver to 1.0.7 this morning and just noticed that my dashboard tiles are showing data from this morning from before I update Tile Driver. If I look at the Data and Tile devices the data is current with the most recent updates but that is not what I'm seeing on the dashboards. Seeing the same thing on three different devices with different browsers and the app so not a local cache issue with browser.
I noticed that I have to switch attributes they now start with bpt-
From my dashboard when I look at the attributes I see currentDataTile (what I was using) and now bpt-currentDataTile (what I switched to for current data). Looking at the Tile device there is on bpt-currentDataTile.
I just installed your app and am getting around to configuring the child, and when i change the font to 10 instead of 15, it only changes 1 number and not the whole tile's text.. I know i have to be missing something.. here's a screen shot of the different fonts:
