New version on GitHub...
Child:
1.0.4 - 08/03/20 - Adjustments
Child:
I have updated to the latest 1.0.4 and am observing the same behavior that the bulb turns on...but never gets brighter during DIMUP.
Interesting that the bulb you using is the same brand as the other user... both are Inovelli. If you look in your log you can see the command being sent In 'setLevelColorHandler ... level: 1' but the bulb is still turning on at 80 (it's previous level).
Well the funny thing is that Gentle Wake Up works just fine with the bulb and that is setting the level, correct? When I use Gentle Wake Up, the bulb changes colors, temperature, and brightness.
BTW, here is a video of what I see using WMU with my current settings. Also note that the bulb does not turn off...it just stays on like this forever once WMU runs.
Updated to latest version. This seems to be better, but still one quirk. I set the beginning dim to 10% and ending at 99%. As the logs show, it came on to 10%, but quickly jumped to 40%. From there it ramped to 99% just fine.
Admittedly the ramp time I chose was fairly short 15 minutes (for testing purposes), so I am not sure if this skipping large chunks of brightness strategy is normal, or whether it is truly a bug?
And two more with equally inconsistent results. Both were with the same 15 minute timer as the run above, and no other changes except to start and ending levels as noted below. I truncated these logs a bit on the second run, but I would be glad to provide others, or try other settings as needed.
This run was set for 10%-50%, it turned on at the proper level and promptly timed out. The previous bulb level (from the trial above) was 99%, and it appears that it saw that and thought it reached the goal.
On the next try, I had it set for 25%-75%. It came on at 25%, very quickly dimmed to 10%, and then ramped up from that 10% to the proper 75%. I am not sure where it got the 10% as there is nothing showing in the UI for that level at this point.
08/04/20 - Try try again, found an error with dim down
Logs have been great, keep them coming
Just broke down and ordered an Inovelli Ilumin RGBW bulb and a Sylvania Smart+ ZigBee Bulb, Color Changing and Dimmable. Should be able to start testing them Thursday afternoon.
Ok this time I tried DimDown and was encouraged because at least something changed on the bulb. It started and was working down. However, it was done very fast. I had it set for 5mins and it was done in 40 seconds. Please note that I set the level to 50% and then turned the bulb off before allowing WMU to trigger.
So I ran it again to time it and then it didn't work correctly. I believe it thought it was already at the target and just stopped. I will try to recreate that and get logs.
Right now when I run it
And if I run/trigger it again without manually setting level beforehand, it's all done in 10 seconds....
1.0.7 - 08/04/20 - reworked some math
I have done multiple run through with this 1.07 and the previous 08/04/2020 (1.06?) version. Since that first 08/04 update, the dimming seems to get stuck in a loop of some type, and repeatedly keeps trying to set the same level.
It never ended the automation even after the 15 minute timer expired, it ran well over 30 minutes before I had to stop it manually by turning off the bulb via dashboard.
Here is a sample of what is happening. I tried multiple timer variations, starting and ending levels. It does the same thing no matter the settings.
Let me know if you need more info or additional logs.
Show me how you have it setup. I've run it with 2 different types of bulbs now (Hue and Lightify) and it's working perfect.
Very weird. I think I'm going to give up until the bulbs I ordered come in.
This is not the same run as above, but it still happened with these settings. Nothing else is selected or changed other than what is shown.
I wonder if I should try a clean install of it? I have up until now just run the update, gone into the child to check settings, and Done out of the app.
Thanks to the great screenshots.
1.0.9 - 08/04/20 - Can now choose multiple lights with slow up/down
Slow down! I can't keep up! I was just testing the last release, and now I have to update again?
Thank goodness for Package Manager.
1.08 seems to have fixed the dim up issues, I just ran one successful 15 minute test from 10%-50% brightness.
Will update to 1.09 and do some further testing.
Ok, I just got my new Sengled Element Color Plus Zigbee(S) bulb today. I am now testing this new bulb and my original Inovelli color bulb(I) next to each other. Note that both are in the exact same style lamps.
Below are my DimUP results:
DimUP - 5mins/5-90 "Daylight - Energize"
S: Light comes on BLUE, initial level seems bright for 5%, brightens consistently through cycle, color remains blue, why is it always blue?
I: Light comes on BLUE, initial level is very low..5% seems accurate, Never changes or gets any brighter through entire cycle
app:1452020-08-14 05:45:16.344 pm debug-------------------- End dimStepUp --------------------
app:1452020-08-14 05:45:16.340 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:45:16.337 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:45:16.328 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:45:11.306 pm infoLT Sengled Color level was set to 90%
dev:72020-08-14 05:45:07.306 pm infoLT Color Inovelli was set to 90%
dev:72020-08-14 05:45:07.298 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:45:06.224 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:45:06.194 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:45:06.188 pm debugIn dimStepUp - Setting currentLevel: 90 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:45:06.185 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:45:06.181 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:45:06.171 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:45:01.186 pm infoLT Sengled Color level was set to 89%
dev:72020-08-14 05:44:57.184 pm infoLT Color Inovelli was set to 89%
dev:72020-08-14 05:44:57.176 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:44:56.083 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:44:56.046 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:44:56.040 pm debugIn dimStepUp - Setting currentLevel: 89.9999999940 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:44:56.036 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:44:56.033 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:44:56.025 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:44:50.989 pm infoLT Sengled Color level was set to 88%
dev:72020-08-14 05:44:46.991 pm infoLT Color Inovelli was set to 88%
dev:72020-08-14 05:44:46.981 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:44:45.903 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:44:45.874 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:44:45.867 pm debugIn dimStepUp - Setting currentLevel: 88.5593220280 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:44:45.864 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:44:45.861 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:44:45.851 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:44:40.842 pm infoLT Sengled Color level was set to 87%
dev:72020-08-14 05:44:36.885 pm infoLT Color Inovelli was set to 87%
dev:72020-08-14 05:44:36.877 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:44:35.753 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:44:35.723 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:44:35.717 pm debugIn dimStepUp - Setting currentLevel: 87.1186440620 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:44:35.714 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:44:35.710 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:44:35.702 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:44:30.679 pm infoLT Sengled Color level was set to 85%
dev:72020-08-14 05:44:26.694 pm infoLT Color Inovelli was set to 85%
dev:72020-08-14 05:44:26.686 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:44:25.585 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:44:25.547 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:44:25.541 pm debugIn dimStepUp - Setting currentLevel: 85.6779660960 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:44:25.537 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:44:25.533 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:44:25.525 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:44:20.515 pm infoLT Sengled Color level was set to 84%
dev:72020-08-14 05:44:16.553 pm infoLT Color Inovelli was set to 84%
dev:72020-08-14 05:44:16.545 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:44:15.429 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:44:15.398 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:44:15.391 pm debugIn dimStepUp - Setting currentLevel: 84.2372881300 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:44:15.388 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:44:15.384 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:44:15.375 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:44:10.338 pm infoLT Sengled Color level was set to 82%
dev:72020-08-14 05:44:06.362 pm infoLT Color Inovelli was set to 82%
dev:72020-08-14 05:44:06.354 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:44:05.245 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:44:05.213 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:44:05.206 pm debugIn dimStepUp - Setting currentLevel: 82.7966101640 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:44:05.202 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:44:05.199 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:44:05.188 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:44:00.174 pm infoLT Sengled Color level was set to 81%
dev:72020-08-14 05:43:56.220 pm infoLT Color Inovelli was set to 81%
dev:72020-08-14 05:43:56.212 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:43:55.087 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:43:55.046 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:43:55.040 pm debugIn dimStepUp - Setting currentLevel: 81.3559321980 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:43:55.037 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:43:55.033 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:43:55.024 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:43:50.013 pm infoLT Sengled Color level was set to 79%
dev:72020-08-14 05:43:45.971 pm infoLT Color Inovelli was set to 79%
dev:72020-08-14 05:43:45.964 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:43:44.916 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:43:44.870 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:43:44.863 pm debugIn dimStepUp - Setting currentLevel: 79.9152542320 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:43:44.859 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:43:44.856 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:43:44.837 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:43:39.817 pm infoLT Sengled Color level was set to 78%
dev:72020-08-14 05:43:35.859 pm infoLT Color Inovelli was set to 78%
dev:72020-08-14 05:43:35.810 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:43:34.722 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:43:34.684 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:43:34.648 pm debugIn dimStepUp - Setting currentLevel: 78.4745762660 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:43:34.645 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:43:34.642 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:43:34.603 pm debug-------------------- dimStepUp --------------------
dev:812020-08-14 05:43:30.912 pm info'switch' set to 'off'
dev:802020-08-14 05:43:30.888 pm info'switch' set to 'off'
dev:792020-08-14 05:43:30.847 pm info'switch' set to 'off'
dev:782020-08-14 05:43:30.816 pm info'switch' set to 'off'
dev:772020-08-14 05:43:30.797 pm infoparseResult: [Time:2020-08-14T17:43:29, Uptime:7T21:40:14, UptimeSec:682814, Heap:26, SleepMode:Dynamic, Sleep:50, LoadAvg:19, MqttCount:0, POWER1:OFF, POWER2:OFF, POWER3:OFF, POWER4:OFF, Wifi:[AP:1, SSId:BARIOT, BSSId:E6:F4:C6:0F:67:50, Channel:7, RSSI:58, Signal:-71, LinkCount:2, Downtime:0T00:01:20]]
dev:862020-08-14 05:43:29.579 pm infoLT Sengled Color level was set to 77%
dev:72020-08-14 05:43:25.618 pm infoLT Color Inovelli was set to 77%
dev:72020-08-14 05:43:25.607 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:43:24.469 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:43:24.431 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:43:24.424 pm debugIn dimStepUp - Setting currentLevel: 77.0338983000 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:43:24.421 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:43:24.417 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:43:24.407 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:43:19.368 pm infoLT Sengled Color level was set to 75%
dev:72020-08-14 05:43:15.373 pm infoLT Color Inovelli was set to 75%
dev:72020-08-14 05:43:15.365 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:43:14.278 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:43:14.246 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:43:14.239 pm debugIn dimStepUp - Setting currentLevel: 75.5932203340 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:43:14.236 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:43:14.233 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:43:14.223 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:43:09.213 pm infoLT Sengled Color level was set to 74%
dev:72020-08-14 05:43:05.212 pm infoLT Color Inovelli was set to 74%
dev:72020-08-14 05:43:05.204 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:43:04.113 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:43:04.074 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:43:04.067 pm debugIn dimStepUp - Setting currentLevel: 74.1525423680 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:43:04.064 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:43:04.061 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:43:04.052 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:42:58.997 pm infoLT Sengled Color level was set to 72%
dev:72020-08-14 05:42:54.991 pm infoLT Color Inovelli was set to 72%
dev:72020-08-14 05:42:54.984 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:42:53.904 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:42:53.858 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:42:53.848 pm debugIn dimStepUp - Setting currentLevel: 72.7118644020 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:42:53.844 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:42:53.841 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:42:53.832 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:42:48.797 pm infoLT Sengled Color level was set to 71%
dev:72020-08-14 05:42:44.813 pm infoLT Color Inovelli was set to 71%
dev:72020-08-14 05:42:44.804 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:42:43.704 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:42:43.675 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:42:43.665 pm debugIn dimStepUp - Setting currentLevel: 71.2711864360 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:42:43.662 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:42:43.659 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:42:43.647 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:42:38.617 pm infoLT Sengled Color level was set to 69%
dev:72020-08-14 05:42:34.626 pm infoLT Color Inovelli was set to 69%
dev:72020-08-14 05:42:34.618 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:42:33.521 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:42:33.490 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:42:33.482 pm debugIn dimStepUp - Setting currentLevel: 69.8305084700 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:42:33.479 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:42:33.476 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:42:33.465 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:42:28.440 pm infoLT Sengled Color level was set to 68%
dev:72020-08-14 05:42:24.465 pm infoLT Color Inovelli was set to 68%
dev:72020-08-14 05:42:24.456 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:42:23.355 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:42:23.321 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:42:23.313 pm debugIn dimStepUp - Setting currentLevel: 68.3898305040 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:42:23.310 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:42:23.307 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:42:23.295 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:42:18.270 pm infoLT Sengled Color level was set to 66%
dev:72020-08-14 05:42:14.267 pm infoLT Color Inovelli was set to 66%
dev:72020-08-14 05:42:14.258 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:42:13.174 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:42:13.139 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:42:13.130 pm debugIn dimStepUp - Setting currentLevel: 66.9491525380 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:42:13.126 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:42:13.122 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:42:13.114 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:42:08.089 pm infoLT Sengled Color level was set to 65%
dev:72020-08-14 05:42:04.105 pm infoLT Color Inovelli was set to 65%
dev:72020-08-14 05:42:04.095 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:42:02.998 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:42:02.942 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:42:02.933 pm debugIn dimStepUp - Setting currentLevel: 65.5084745720 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:42:02.930 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:42:02.926 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:42:02.916 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:41:57.881 pm infoLT Sengled Color level was set to 64%
dev:72020-08-14 05:41:53.911 pm infoLT Color Inovelli was set to 64%
dev:72020-08-14 05:41:53.900 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:41:52.781 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:41:52.746 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:41:52.737 pm debugIn dimStepUp - Setting currentLevel: 64.0677966060 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:41:52.733 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:41:52.730 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:41:52.719 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:41:47.674 pm infoLT Sengled Color level was set to 62%
dev:72020-08-14 05:41:43.688 pm infoLT Color Inovelli was set to 62%
dev:72020-08-14 05:41:43.677 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:41:42.584 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:41:42.539 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:41:42.531 pm debugIn dimStepUp - Setting currentLevel: 62.6271186400 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:41:42.526 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:41:42.521 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:41:42.512 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:41:37.494 pm infoLT Sengled Color level was set to 61%
dev:72020-08-14 05:41:33.507 pm infoLT Color Inovelli was set to 61%
dev:72020-08-14 05:41:33.495 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:41:32.395 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:41:32.363 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:41:32.355 pm debugIn dimStepUp - Setting currentLevel: 61.1864406740 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:41:32.351 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:41:32.348 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:41:32.339 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:41:27.317 pm infoLT Sengled Color level was set to 59%
dev:72020-08-14 05:41:23.347 pm infoLT Color Inovelli was set to 59%
dev:72020-08-14 05:41:23.338 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:41:22.237 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:41:22.205 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:41:22.197 pm debugIn dimStepUp - Setting currentLevel: 59.7457627080 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:41:22.194 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:41:22.191 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:41:22.182 pm debug-------------------- dimStepUp --------------------
dev:732020-08-14 05:41:18.929 pm infoLT Front Door Right was turned off [physical]
dev:862020-08-14 05:41:17.146 pm infoLT Sengled Color level was set to 58%
dev:732020-08-14 05:41:15.274 pm infoLT Front Door Right was turned on [physical]
dev:72020-08-14 05:41:13.180 pm infoLT Color Inovelli was set to 58%
dev:72020-08-14 05:41:13.171 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:41:12.061 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:41:12.019 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:41:12.011 pm debugIn dimStepUp - Setting currentLevel: 58.3050847420 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:41:12.008 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:41:12.005 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:41:11.995 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:41:06.928 pm infoLT Sengled Color level was set to 56%
dev:72020-08-14 05:41:02.911 pm infoLT Color Inovelli was set to 56%
dev:72020-08-14 05:41:02.902 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:41:01.831 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:41:01.799 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:41:01.791 pm debugIn dimStepUp - Setting currentLevel: 56.8644067760 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:41:01.788 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:41:01.785 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:41:01.775 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:40:56.789 pm infoLT Sengled Color level was set to 55%
dev:72020-08-14 05:40:52.799 pm infoLT Color Inovelli was set to 55%
dev:72020-08-14 05:40:52.790 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:40:51.677 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:40:51.624 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:40:51.616 pm debugIn dimStepUp - Setting currentLevel: 55.4237288100 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:40:51.613 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:40:51.609 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:40:51.600 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:40:46.556 pm infoLT Sengled Color level was set to 53%
dev:72020-08-14 05:40:42.574 pm infoLT Color Inovelli was set to 53%
dev:72020-08-14 05:40:42.565 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:40:41.466 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:40:41.435 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:40:41.427 pm debugIn dimStepUp - Setting currentLevel: 53.9830508440 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:40:41.424 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:40:41.420 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:40:41.410 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:40:36.395 pm infoLT Sengled Color level was set to 52%
dev:72020-08-14 05:40:32.406 pm infoLT Color Inovelli was set to 52%
dev:72020-08-14 05:40:32.397 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:40:31.301 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:40:31.268 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:40:31.260 pm debugIn dimStepUp - Setting currentLevel: 52.5423728780 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:40:31.257 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:40:31.253 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:40:31.244 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:40:26.241 pm infoLT Sengled Color level was set to 51%
dev:72020-08-14 05:40:22.269 pm infoLT Color Inovelli was set to 51%
dev:72020-08-14 05:40:22.260 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:40:21.148 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:40:21.111 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:40:21.102 pm debugIn dimStepUp - Setting currentLevel: 51.1016949120 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:40:21.099 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:40:21.095 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:40:21.085 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:40:16.075 pm infoLT Sengled Color level was set to 49%
dev:72020-08-14 05:40:12.085 pm infoLT Color Inovelli was set to 49%
dev:72020-08-14 05:40:12.077 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:40:10.981 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:40:10.946 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:40:10.939 pm debugIn dimStepUp - Setting currentLevel: 49.6610169460 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:40:10.935 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:40:10.932 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:40:10.922 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:40:05.884 pm infoLT Sengled Color level was set to 48%
dev:72020-08-14 05:40:01.902 pm infoLT Color Inovelli was set to 48%
dev:72020-08-14 05:40:01.894 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:40:00.802 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:40:00.758 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:40:00.748 pm debugIn dimStepUp - Setting currentLevel: 48.2203389800 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:40:00.745 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:40:00.742 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:40:00.732 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:39:55.702 pm infoLT Sengled Color level was set to 46%
dev:72020-08-14 05:39:51.707 pm infoLT Color Inovelli was set to 46%
dev:72020-08-14 05:39:51.698 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:39:50.610 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:39:50.577 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:39:50.569 pm debugIn dimStepUp - Setting currentLevel: 46.7796610140 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:39:50.566 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:39:50.563 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:39:50.552 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:39:45.536 pm infoLT Sengled Color level was set to 45%
dev:72020-08-14 05:39:41.555 pm infoLT Color Inovelli was set to 45%
dev:72020-08-14 05:39:41.545 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:39:40.437 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:39:40.391 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:39:40.380 pm debugIn dimStepUp - Setting currentLevel: 45.3389830480 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:39:40.376 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:39:40.373 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:39:40.362 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:39:35.295 pm infoLT Sengled Color level was set to 43%
dev:72020-08-14 05:39:31.322 pm infoLT Color Inovelli was set to 43%
dev:72020-08-14 05:39:31.313 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:39:30.210 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:39:30.180 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:39:30.172 pm debugIn dimStepUp - Setting currentLevel: 43.8983050820 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:39:30.168 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:39:30.165 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:39:30.155 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:39:25.158 pm infoLT Sengled Color level was set to 42%
dev:72020-08-14 05:39:21.118 pm infoLT Color Inovelli was set to 42%
dev:72020-08-14 05:39:21.110 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:39:20.050 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:39:20.008 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:39:20.000 pm debugIn dimStepUp - Setting currentLevel: 42.4576271160 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:39:19.996 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:39:19.992 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:39:19.981 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:39:14.958 pm infoLT Sengled Color level was set to 41%
dev:72020-08-14 05:39:10.963 pm infoLT Color Inovelli was set to 41%
dev:72020-08-14 05:39:10.950 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:39:09.885 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:39:09.861 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:39:09.849 pm debugIn dimStepUp - Setting currentLevel: 41.0169491500 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:39:09.839 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:39:09.835 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:39:09.819 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:39:04.826 pm infoLT Sengled Color level was set to 39%
dev:72020-08-14 05:39:00.849 pm infoLT Color Inovelli was set to 39%
dev:72020-08-14 05:39:00.840 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:38:59.738 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:38:59.707 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:38:59.700 pm debugIn dimStepUp - Setting currentLevel: 39.5762711840 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:38:59.696 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:38:59.693 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:38:59.682 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:38:54.681 pm infoLT Sengled Color level was set to 38%
dev:72020-08-14 05:38:50.711 pm infoLT Color Inovelli was set to 38%
dev:72020-08-14 05:38:50.701 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:38:49.589 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:38:49.559 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:38:49.553 pm debugIn dimStepUp - Setting currentLevel: 38.1355932180 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:38:49.549 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:38:49.546 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:38:49.508 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:38:44.491 pm infoLT Sengled Color level was set to 36%
dev:72020-08-14 05:38:40.495 pm infoLT Color Inovelli was set to 36%
dev:72020-08-14 05:38:40.487 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:38:39.399 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:38:39.354 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:38:39.347 pm debugIn dimStepUp - Setting currentLevel: 36.6949152520 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:38:39.342 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:38:39.338 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:38:39.326 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:38:34.323 pm infoLT Sengled Color level was set to 35%
dev:822020-08-14 05:38:33.601 pm infoMO Driveway Motion motion is inactive
dev:812020-08-14 05:38:30.871 pm info'switch' set to 'off'
dev:802020-08-14 05:38:30.851 pm info'switch' set to 'off'
dev:792020-08-14 05:38:30.822 pm info'switch' set to 'off'
dev:782020-08-14 05:38:30.797 pm info'switch' set to 'off'
dev:772020-08-14 05:38:30.780 pm infoparseResult: [Time:2020-08-14T17:38:29, Uptime:7T21:35:14, UptimeSec:682514, Heap:26, SleepMode:Dynamic, Sleep:50, LoadAvg:19, MqttCount:0, POWER1:OFF, POWER2:OFF, POWER3:OFF, POWER4:OFF, Wifi:[AP:1, SSId:BARIOT, BSSId:E6:F4:C6:0F:67:50, Channel:7, RSSI:62, Signal:-69, LinkCount:2, Downtime:0T00:01:20]]
dev:72020-08-14 05:38:30.327 pm infoLT Color Inovelli was set to 35%
dev:72020-08-14 05:38:30.318 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:38:29.203 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:38:29.173 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:38:29.166 pm debugIn dimStepUp - Setting currentLevel: 35.2542372860 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:38:29.163 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:38:29.160 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:38:29.149 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:38:24.077 pm infoLT Sengled Color level was set to 33%
dev:822020-08-14 05:38:23.059 pm infoMO Driveway Motion motion is active
dev:72020-08-14 05:38:20.118 pm infoLT Color Inovelli was set to 33%
dev:72020-08-14 05:38:20.110 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:38:19.012 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:38:18.980 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:38:18.973 pm debugIn dimStepUp - Setting currentLevel: 33.8135593200 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:38:18.970 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:38:18.967 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:38:18.956 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:38:13.921 pm infoLT Sengled Color level was set to 32%
dev:72020-08-14 05:38:09.956 pm infoLT Color Inovelli was set to 32%
dev:72020-08-14 05:38:09.947 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:38:08.827 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:38:08.787 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:38:08.780 pm debugIn dimStepUp - Setting currentLevel: 32.3728813540 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:38:08.776 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:38:08.773 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:38:08.762 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:38:03.711 pm infoLT Sengled Color level was set to 30%
dev:72020-08-14 05:37:59.686 pm infoLT Color Inovelli was set to 30%
dev:72020-08-14 05:37:59.679 pm infoLT Color Inovelli was turned on
dev:822020-08-14 05:37:59.651 pm infoMO Driveway Motion illuminance is 900lux
app:1452020-08-14 05:37:58.628 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:37:58.596 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:37:58.588 pm debugIn dimStepUp - Setting currentLevel: 30.9322033880 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:37:58.584 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:37:58.581 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:37:58.569 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:37:53.577 pm infoLT Sengled Color level was set to 29%
dev:72020-08-14 05:37:49.537 pm infoLT Color Inovelli was set to 29%
dev:72020-08-14 05:37:49.527 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:37:48.437 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:37:48.396 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:37:48.389 pm debugIn dimStepUp - Setting currentLevel: 29.4915254220 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:37:48.386 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:37:48.382 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:37:48.372 pm debug-------------------- dimStepUp --------------------
dev:732020-08-14 05:37:43.496 pm infoLT Front Door Right was turned off [physical]
dev:862020-08-14 05:37:43.334 pm infoLT Sengled Color level was set to 28%
dev:72020-08-14 05:37:39.365 pm infoLT Color Inovelli was set to 28%
dev:72020-08-14 05:37:39.357 pm infoLT Color Inovelli was turned on
dev:732020-08-14 05:37:38.279 pm infoLT Front Door Right was turned on [physical]
app:1452020-08-14 05:37:38.255 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:37:38.216 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:37:38.209 pm debugIn dimStepUp - Setting currentLevel: 28.0508474560 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:37:38.206 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:37:38.203 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:37:38.192 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:37:33.173 pm infoLT Sengled Color level was set to 26%
dev:72020-08-14 05:37:29.186 pm infoLT Color Inovelli was set to 26%
dev:72020-08-14 05:37:29.177 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:37:28.087 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:37:28.054 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:37:28.048 pm debugIn dimStepUp - Setting currentLevel: 26.6101694900 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:37:28.045 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:37:28.041 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:37:28.030 pm debug-------------------- dimStepUp --------------------
dev:732020-08-14 05:37:24.836 pm infoLT Front Door Right was turned off [physical]
dev:862020-08-14 05:37:23.011 pm infoLT Sengled Color level was set to 25%
dev:72020-08-14 05:37:19.055 pm infoLT Color Inovelli was set to 25%
dev:72020-08-14 05:37:19.047 pm infoLT Color Inovelli was turned on
dev:732020-08-14 05:37:18.198 pm infoLT Front Door Right was turned on [physical]
app:1452020-08-14 05:37:17.925 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:37:17.891 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:37:17.885 pm debugIn dimStepUp - Setting currentLevel: 25.1694915240 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:37:17.882 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:37:17.878 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:37:17.865 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:37:12.856 pm infoLT Sengled Color level was set to 23%
dev:72020-08-14 05:37:08.848 pm infoLT Color Inovelli was set to 23%
dev:72020-08-14 05:37:08.840 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:37:07.756 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:37:07.719 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:37:07.712 pm debugIn dimStepUp - Setting currentLevel: 23.7288135580 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:37:07.709 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:37:07.706 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:37:07.692 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:37:02.644 pm infoLT Sengled Color level was set to 22%
dev:72020-08-14 05:36:58.652 pm infoLT Color Inovelli was set to 22%
dev:72020-08-14 05:36:58.643 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:36:57.549 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:36:57.504 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:36:57.497 pm debugIn dimStepUp - Setting currentLevel: 22.2881355920 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:36:57.490 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:36:57.486 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:36:57.474 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:36:52.434 pm infoLT Sengled Color level was set to 20%
dev:72020-08-14 05:36:48.384 pm infoLT Color Inovelli was set to 20%
dev:72020-08-14 05:36:48.377 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:36:47.322 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:36:47.283 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:36:47.276 pm debugIn dimStepUp - Setting currentLevel: 20.8474576260 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:36:47.273 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:36:47.270 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:36:47.259 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:36:42.211 pm infoLT Sengled Color level was set to 19%
dev:72020-08-14 05:36:38.229 pm infoLT Color Inovelli was set to 19%
dev:72020-08-14 05:36:38.221 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:36:37.131 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:36:37.102 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:36:37.094 pm debugIn dimStepUp - Setting currentLevel: 19.4067796600 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:36:37.091 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:36:37.088 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:36:37.076 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:36:32.067 pm infoLT Sengled Color level was set to 17%
dev:72020-08-14 05:36:28.103 pm infoLT Color Inovelli was set to 17%
dev:72020-08-14 05:36:28.094 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:36:26.983 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:36:26.952 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:36:26.945 pm debugIn dimStepUp - Setting currentLevel: 17.9661016940 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:36:26.942 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:36:26.939 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:36:26.928 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:36:21.896 pm infoLT Sengled Color level was set to 16%
dev:72020-08-14 05:36:17.912 pm infoLT Color Inovelli was set to 16%
dev:72020-08-14 05:36:17.902 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:36:16.806 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:36:16.767 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:36:16.760 pm debugIn dimStepUp - Setting currentLevel: 16.5254237280 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:36:16.757 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:36:16.754 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:36:16.743 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:36:11.699 pm infoLT Sengled Color level was set to 15%
dev:72020-08-14 05:36:07.711 pm infoLT Color Inovelli was set to 15%
dev:72020-08-14 05:36:07.703 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:36:06.605 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:36:06.555 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:36:06.549 pm debugIn dimStepUp - Setting currentLevel: 15.0847457620 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:36:06.545 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:36:06.542 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:36:06.530 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:36:01.467 pm infoLT Sengled Color level was set to 13%
dev:72020-08-14 05:35:57.494 pm infoLT Color Inovelli was set to 13%
dev:72020-08-14 05:35:57.485 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:35:56.381 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:35:56.346 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:35:56.339 pm debugIn dimStepUp - Setting currentLevel: 13.6440677960 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:35:56.336 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:56.333 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:35:56.323 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:35:51.262 pm infoLT Sengled Color level was set to 12%
dev:72020-08-14 05:35:47.307 pm infoLT Color Inovelli was set to 12%
dev:72020-08-14 05:35:47.278 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:35:46.177 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:35:46.139 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:35:46.130 pm debugIn dimStepUp - Setting currentLevel: 12.2033898300 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:35:46.126 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:46.122 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:35:46.107 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:35:41.062 pm infoLT Sengled Color level was set to 10%
dev:72020-08-14 05:35:37.079 pm infoLT Color Inovelli was set to 10%
dev:72020-08-14 05:35:37.070 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:35:35.972 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:35:35.930 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:35:35.923 pm debugIn dimStepUp - Setting currentLevel: 10.7627118640 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:35:35.919 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:35.916 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:35:35.907 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:35:30.911 pm infoLT Sengled Color level was set to 9%
dev:72020-08-14 05:35:26.908 pm infoLT Color Inovelli was set to 9%
dev:72020-08-14 05:35:26.898 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:35:25.787 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:35:25.747 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:35:25.739 pm debugIn dimStepUp - Setting currentLevel: 9.3220338980 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:35:25.736 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:25.732 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:35:25.722 pm debug-------------------- dimStepUp --------------------
dev:862020-08-14 05:35:20.717 pm infoLT Sengled Color level was set to 7%
dev:72020-08-14 05:35:16.724 pm infoLT Color Inovelli was set to 7%
dev:72020-08-14 05:35:16.712 pm infoLT Color Inovelli was turned on
app:1452020-08-14 05:35:15.619 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:35:15.587 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:35:15.579 pm debugIn dimStepUp - Setting currentLevel: 7.8813559320 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:35:15.576 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:15.573 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:35:15.565 pm debug-------------------- dimStepUp --------------------
dev:732020-08-14 05:35:07.464 pm infoLT Front Door Right was turned off [physical]
dev:72020-08-14 05:35:06.515 pm infoLT Color Inovelli was set to 6%
dev:72020-08-14 05:35:06.506 pm infoLT Color Inovelli was turned on
dev:862020-08-14 05:35:05.690 pm infoLT Sengled Color level was set to 6%
app:1452020-08-14 05:35:05.427 pm debugIn dimStepUp - LT Sengled Color is: on
app:1452020-08-14 05:35:05.385 pm debugIn dimStepUp - LT Color Inovelli is: on
app:1452020-08-14 05:35:05.376 pm debugIn dimStepUp - Setting currentLevel: 6.4406779660 - dimStep: 1.4406779660 - targetLevel: 90
app:1452020-08-14 05:35:05.373 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:05.369 pm debugIn dimStepUp (1.0.9)
app:1452020-08-14 05:35:05.358 pm debug-------------------- dimStepUp --------------------
dev:732020-08-14 05:35:03.416 pm infoLT Front Door Right was turned on [physical]
dev:72020-08-14 05:35:00.969 pm infoLT Color Inovelli level is 5%
dev:72020-08-14 05:35:00.915 pm infoLT Color Inovelli color is Cyan
dev:72020-08-14 05:35:00.894 pm infoLT Color Inovelli saturation is 85
dev:862020-08-14 05:35:00.890 pm infoLT Sengled Color was turned on
dev:862020-08-14 05:35:00.871 pm infoLT Sengled Color saturation was set to 91%
dev:72020-08-14 05:35:00.861 pm infoLT Color Inovelli hue is 53
dev:72020-08-14 05:35:00.833 pm infoLT Color Inovelli color is #020b0d
dev:72020-08-14 05:35:00.829 pm infoLT Color Inovelli was set to 5%
dev:72020-08-14 05:35:00.805 pm infoLT Color Inovelli was turned on
dev:72020-08-14 05:35:00.620 pm infoLT Color Inovelli level is 99%
dev:862020-08-14 05:35:00.597 pm infoLT Sengled Color hue was set to 53%
dev:72020-08-14 05:35:00.579 pm infoLT Color Inovelli level is 99%
dev:72020-08-14 05:35:00.570 pm infoLT Color Inovelli color is Blue
dev:72020-08-14 05:35:00.547 pm infoLT Color Inovelli saturation is 99
dev:72020-08-14 05:35:00.537 pm infoLT Color Inovelli hue is 66
dev:72020-08-14 05:35:00.524 pm infoLT Color Inovelli color is #020bfc
dev:72020-08-14 05:35:00.499 pm infoLT Color Inovelli color is Cyan
dev:72020-08-14 05:35:00.496 pm infoLT Color Inovelli saturation is 99
dev:72020-08-14 05:35:00.482 pm infoLT Color Inovelli hue is 50
dev:72020-08-14 05:35:00.471 pm infoLT Color Inovelli level is 99%
dev:72020-08-14 05:35:00.467 pm infoLT Color Inovelli color is #02f7fc
dev:72020-08-14 05:35:00.458 pm infoLT Color Inovelli color is Cyan
dev:72020-08-14 05:35:00.445 pm infoLT Color Inovelli saturation is 19
dev:72020-08-14 05:35:00.437 pm infoLT Color Inovelli hue is 52
dev:72020-08-14 05:35:00.401 pm infoLT Color Inovelli color is #ccf7fc
dev:72020-08-14 05:35:00.387 pm infoLT Color Inovelli level is 99%
dev:72020-08-14 05:35:00.361 pm infoLT Color Inovelli color is Cyan
dev:72020-08-14 05:35:00.316 pm infoLT Color Inovelli saturation is 19
dev:72020-08-14 05:35:00.308 pm infoLT Color Inovelli hue is 52
dev:72020-08-14 05:35:00.277 pm infoLT Color Inovelli color is #ccf7fc
app:1452020-08-14 05:35:00.253 pm debugslowOnHandler - dimStep: 1.4406779660 - targetLevel: 90 - color: Daylight
app:1452020-08-14 05:35:00.188 pm debugIn setLevelandColorHandler - LT Sengled Color, setColor([hue:53, saturation:91, level:5])
dev:72020-08-14 05:35:00.169 pm infoLT Color Inovelli color mode is RGB
app:1452020-08-14 05:35:00.144 pm debugIn setLevelandColorHandler - LT Color Inovelli, setColor([hue:53, saturation:91, level:5])
app:1452020-08-14 05:35:00.140 pm debugIn setLevelandColorHandler - slowOn
app:1452020-08-14 05:35:00.137 pm debugIn setLevelandColorHandler - value: [hue:53, saturation:91, level:5]
app:1452020-08-14 05:35:00.134 pm debugIn setLevelandColorHandler (1.0.9) - fromWhere: slowOn, onLevel: 5, color: Daylight
app:1452020-08-14 05:35:00.130 pm debugIn slowOnHandler (1.0.9)
app:1452020-08-14 05:35:00.127 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:00.124 pm debugIn disableSwitchHandler - Control Switch is set to on.
app:1452020-08-14 05:35:00.121 pm debugIn magicHappensHandler (1.0.9) - CS: on
app:1452020-08-14 05:35:00.117 pm debugIn dayOfTheWeekHandler - daysMatch: true
app:1452020-08-14 05:35:00.114 pm debugIn dayOfTheWeekHandler - Days of the Week Passed
app:1452020-08-14 05:35:00.111 pm debugIn dayOfTheWeek (1.0.9)
DimUP - 3mins/5-90 "White - Concentrate"
S: Now it's WHITE, brightens consistently through cycle
I: Now it's WHITE, initial level is very low..5% seems accurate, Never changes or gets any brighter through entire cycle
<<SNIP Summary - Said too many characters>>
DimUP - 3mins/5-90 "Red"
S: Comes on RED, brightens consistently through cycle
I: Comes on RED, initial level is very low..5% seems accurate, Never changes or gets any brighter through entire cycle
NOTES
