I just did set pin code on all ecobees and didnt tell anybody what is it.
workaround was direct connection ecobee =>alexa voice control
but kids discovered it so i turn that off too.
And the battle has begun....
getting this error on that rule
app:16652020-04-23 14:26:29.460 infothermostatOperatingState: idle
app:16652020-04-23 14:21:34.405 errorjava.lang.NullPointerException: Cannot invoke method leftShift() on null object on line 274 (opStateHandler)
Ecobee Suite Manager Updated 24 April 2020 at 2:45pm EDT
This update is primarily cosmetic, and all of the SmartApps and Helpers have been updated (the Sensor and Thermostat drivers have not been changed).
I'm not going to list all of the version numbers anymore, but here are the primary non- cosmetic changes:
All Helpers that support Notifications
- Updated to support the latest Echo Speaks Device release 3.6.2.0
All Helpers that change the thermostat's program
- Fixed type conversion issues for hourly holds
Ecobee Suite Manager, version 1.8.38
- Cleaned up connection lost notification text
- Started support for new "climates" enabled by the new Eco+ features (incomplete)
Ecobee Suite Smart Room, version 1.8.15
- Doesn't use Ecobee Sensor as a motion sensor, unless no other motion sensors are configured. This because of the inherent delay in active/inactive changes, which will cause a room to be prematurely activated.
Ecobee Suite Smart Switches, version 1.8.08
- Fixes the logic to save and restore states (reverseActions())
Using Package Managers
I highly recommend that Ecobee Suite users make the small investment in time to setup one of the available automated package managers. This will significantly reduce the manual overhead of upgrading to new releases. Available options include:
SmartThings
- SmartThings GitHub Integration is fully supported by the Ecobee Suite GitHub repository
- SmartThings Community Installer - although this hasn't changed in 2+ years, it remains a powerful tool for automating upgrades for a broad variety of applications and drivers.
Hubitat
- The native "Import" capability should allow you to simply run through all of Ecobee Suite Apps & Drivers doing Import/Confirm/Save.
- The recently released Hubitat Package Manager is really awesome, and I highly recommend it for everyone. It really will make managing your Ecobee Suite environment (and others) MUCH simpler!
These updates are recommended for all Ecobee Suite users
I have the passcode set and my WAF level went down.
Anyways....are there plans to implement a ceiling fan helper? I have (5) rooms that have fans and it would be awesome to have Ecobee control comfort using those too. Thoughts?
Did you update your package.manifest? I haven't seen the update become available for me in HPM.
It showed up for me... what version does him say you have?
What would you like to do?
The Smart Switches Helper can automatically turn on/off switches and/or dimmers based on the Thermostat's operating state - so like "turn on the fan whenever the HVAC is cooling".
Although originally designed to manage airflow using smart vents, you can also use the Smart Vents helper to turn on/off switches/dimmers based on a temperature target (or thermostat) for a given room.
Or, did you have something else in mind?
I was thinking individual room control. So if Ecobee sees a room is hotter/colder than the others/avg it would change the fan to high and once temp avg is achieved reset fan back to original state.
Thoughts?
Did you update without noticing? Those look like the new versions.
His post was 2:54. I didn’t update until 3:30. Not sure.
I do know that GitHub caches read requests, but I don't know if there are more than one cache.
Perhaps the Package Manager needs to do a noCache
HTTP read request to get the packageManager.json
files it uses.
Try the Smart Circulation and/or the Smart Vents & Switches Helpers. Even though they seem focused on opening/closing vents, they can also be used to control ANY switch. The former tries to increase the minimum minutes per hour that the HVAC fan runs, based on temperature deltas across multiple rooms. The latter turns on "vents or switches" when a room is too cold (HVAC in heat mode) or too hot (HVAC in cool mode). Try it with your fans - it MIGHT work...
Note, however, that running a ceiling fan won't cool down the ambient temperature - it just moves air. If you are under the fan, you will feel cooler, but the temperature of the room won't change noticeably.
NOTICE: As of 5 August 2020, Ecobee Suite now supports Ecobee's new authentication scheme
See here for more information
# IMPORTANT WARNING ABOUT ECOBEE 2-FACTOR AUTHENTICATION
Over the past couple of weeks, several users have reported that they are unable to authenticate with Ecobee.
Ecobee Support has acknowledged that there is a problem with 2-Factor Authentication that breaks 3rd party application authentication. Apparently, once you turn 2FA, you won't be able to authenticate any new applications, even if you turn 2FA back off!
Existing applications that are already authenticated seem to continue to operate properly.
Therefore, I recommend to my users:
DO NOT TURN ON ECOBEE 2-FACTOR AUTHENTICATION, UNDER ANY CIRCUMSTANCES!!!!
NOTE: You may have to authenticate again due to an Ecobee server outage, so please don't turn 2FA on even if you have already authenticated.
Ecobee Support says they are working on the problem - I will post an update once I hear that they have fixed their issue.
FWIW, and more data points, I had an existing data connection which stopped working because of the data outage but I didn't know and ended up getting disconnected and had to reauthenticate. I was able to disable 2FA temporarily, reauthenticate, then turn 2FA back on again.
I've been running Ecobee Suite Manager for 6 months or so and love it.
I am having an issue that has been ongoing the whole time, however.
About once or twice a day, I get "]and [ has been open for 10 minutes, Downstairs Thermostat and Upstairs Thermostat are now off" from the Open Contacts App. Looking through the logs and system events, I have not been able to correlate this to any event or see any particular problem, it just seems to happen randomly. However, it is a major issue for the usability of the app because it is randomly turning off my HVAC when a "phantom" device opens. I have to manually turn the hvac back on every time this happens, or wait for another legitimate open/close event to reset it. For a while I just had the helper paused because it was getting too annoying. I really want to be able to use this app because when it works, it works well!
Any idea what could be causing this?
Btw, I am on ecobee Suite Open Contacts version 1.8.12 and
Ecobee Suite Manager 1.8.21 which is about a month old, but I don't see any update notes that mention this issue since then.
Also, should mention that I do not have any contacts open when this event happens.
Usually this is caused by a faulty or low-battery condition in one of the contact sensors that you have configured.
You say that you haven't been able to find anything in the logs - you may need to set up Live Logging and just let it run until it catches one of these events...or maybe if you go to the Log page on your Hubitat and select "Show Past Logs" you might be able to find some clues. The Open Contacts Helper logs every event that it sees in sensorOpened()
and sensorClosed()
(so long as you have debug and info logging enabled), so you should be able to find out the offending device fairly easily...
