Yeah, I’d prefer not to disable polls because if no polls are done for an extended period of time, the device:
will not reflect the actual current status
Take lots of time to complete a refresh - long enough that a requested action (command) doesn’t work.
Over the years, 30 minutes between polls is the absolute minimum (probably should be 15 minutes). Many users (less sophisticated than you) have had poor experience with lengthy intervals, and I’d prefer not to have to deal with a flurry of complaints from users who didn’t take the time to understand the implications.
I’d prefer that you use the 30 minute poll as well, otherwise you’ll have to track my changes (I’ll be releasing 1.9.00 later this week).
Meanwhile, enjoy your customized environment - you use case is why my code is open source donation-ware!
Hi, thanks for this suite of apps. I've tried looking over the old smartthings threads and the ones here, for the "Synchronize Global Pause with this Switch" is this a two way synchronize or a one way from the app Global Pause to switch?
It looks like this was added to support the “Alexa, turn on Global Pause” use case, but I haven't had any luck getting a change in the virtual switch status to reflect in the Global Pause. The other way from Global Pause to virtual switch has been working great.
Made the switch over from the builtin integration to the Ecobee Suite and I am seeing an error with one of the helper apps when I try to enable it. I am able to get to the config screen and select the t-stat, but when clicking on Done, the following error is thrown.
Error: No signature of method: groovy.json.JsonSlurper.parseText() is applicable for argument types: (java.lang.String, java.lang.Boolean) values: [["auto","cool","heat","off"], true] Possible solutions: parseText(java.lang.String)
I have to manually remove the child instance from the settings page to proceed. Other helper apps (At least Contacts and Switch Helper), appear to be working as expected.
Also seeing the below likely unrelated error in the logs as well:
java.lang.NullPointerException: Cannot invoke method generateEvent() on null object on line 2146 (method pollEcobeeAPICallback)
In the interest of full disclosure this was far from what one would call a clean install, so it's not at all unlikely that I caused this in my haste. Via remote admin, I installed and configured Ecobee Suite itself, before removing the built-in integration app. I did not have any existing rules, devices or apps dependent on the Ecobee integration beyond device awareness for cloud based app connectivity.
The above error should include a line number (was apparently truncated in your message).
At that line number of ecobee Thermal Comfort find this line of code:
tm = new JsonSlurper().parseText(theThermostat.currentValue('supportedThermostatModes'), true)
Change that to read:
tm = new JsonSlurper().parseText(theThermostat.currentValue('supportedThermostatModes', true))
Save and retry
As for the other error, I need to know with Application or Device logged this error... if you select the log line containing the error, it should highlight the offending app/device at the top of the logging page.
I can't see my tstat in the help app, try to click to set tstat and there nothing in the drop down...shows up as a device and i can control it but not in Ecobee Suit, expect for the main setup page
hello.. my 4th day using hubitat here. i got this message
Error: No signature of method: basicRule10.parseJson() is applicable for argument types: (java.util.ArrayList) values: [[["off","heat"], ["off","heat"]]]
i see his message is pretty old but this is what i found.
if i try to set the temp on 2 thermostats at the same time i get the error. if i break the setting of temperature into 2 actions i don't get the error.
during the creation of a basic rule. when temperature of sensor is below ## control thermostat. if i pick 1 thermostat it works fine. if i pick 2 thermostats it throws the error instantly
Sounds like a problem with Rule Manager, but I can't tell from your description - what method/routine are you trying to invoke on the Ecobee Suite Thermostats?
Perhaps a screen shot of the Basic Rule you are creating/editing would help me understand better...
Looks like a bug in the Hubitat Basic Rule app - report it to Hubitat Support. Be sure to tell them that you are using BR with my Ecobee Suite - if they say there is a (simple) change I have to make to allow this to work, let me know...
EDIT
You can, of course, simply create two separate actions, one for each thermostat...BR will prompt you to add more actions after the first one is defined...
