Denon Built in Driver VolumeUP/VolumeDown
I am using the Denon Built in Driver to control a Marantz 70S, trying to figure out how to do a volume up/down from a rule or app. The only option that appears in the drop down is to set to a specific volume. The up/down works from the device page but cannot figure out how to access this functionality from a rule. It is Zone 2 showing up as a generic component audio zone under the AVR device.
Have you tried Custom Action?
I did try that but will look at it in a little more detail, thanks for the suggestion!
This means it should be there under custom actions, as @HAL9000 mentioned.
Thanks for the help in getting me going in the right direction, the problem I was having is by default it was sending the Parameters as a “String” and they have to be sent as an “integer”. Learn something new every time I try something new!
