I had my Denon AVR as a device but didn't get around to automating it, then when I tried it wasn't updating so I deleted it and went to re-add it but it can't be found...any tips?
There is no "auto discovery" of AVRs. You have to specify the IP address with in a user created virtual device and then make sure you have ip control enabled within the receivers settings. Also, make sure you have a static ip assigned by your router so the ip address doesn't change.
Solved - thanks!
