I previously posted in the IoTaWatt thread that the most recent HE update bricked the IoTaWatt integration. I decided to roll back to a previous HE version and restored an old database until I had time to try again. Today I updated HE again and added a new IoTaWatt parent which works fine - but I can't delete the old IoTaWatt parent because of this error when trying to access the parent device to delete it.
Since I already took the time to set up a new IoTaWatt parent, is there any way to remove the old parent without having to roll back again? I was able to remove the child devices.
Please don't put in a ticket for broken custom code. Can you post the source of the updated() method for the device you are trying to delete? Can you do a search for "schedule(" in the source and post any lines you've found?
The custom code doesn't seem to be the problem. Applying the most recent hub update broke this particular parent device. I created a new parent using the exact same custom driver code and it works fine.
I'm not sure I understand what you're asking for, but the problem is that I can't access the device page itself -- it returns the posted 404 error rather than the device page. That's why I can't get to the delete button.
Roll back to an earlier hub version and delete the device. Then talk to the developer, "0/180 ... " is not a valid cron expression it must be less than 60.
@epj3 I have corrected the bug in the IoTaWatt Parent driver cod related to allowing invalid cron schedules. The latest version should eliminate this issue. I apologize for the inconvenience.
