Navigate to Rooms from the left-side navigation menu, click/tap into the room you want to remove, then use the red Delete button you should see at the bottom:
Bobby could outright close it, but you could use the 3-dot / ellipsis icon under Robert's post to mark his answer as the "Solution" -- that's a nice way to wrap it up.
