Delay Hangs
I use Delay in several rules, and they all hang on the delay. I created a simple rule to test and confirm. Testing including disabling the Delay to make sure everything else works. This started only recently (a few weeks ago?). I did a soft reset, but that didn't seem to help.
Thank you,
Bob
Can you share logs showing the issue for the example you tried and shared? What platform version are you on?
My first thought would be simultaneous instances creating mayhem if this isn't controlled by private booleans. A wait for elapsed time would probably be a better option for this type of rule.
