Hi I did as instrcted, but it did not solved my problem, please when you have a chance check the images I have added, they maight give you a clue where to solve it.
have a great and happy Xmass and new year.
Please show a screenshot of the Settings portion of the App Status page (gear icon).
What type of device is the one that does work?
I have an idea that perhaps this has something to do with the ones that are failing being component child devices. I will work up a small test app for you to run.
Please show me the portion of your Device list where that one is listed.
Below is the small app. Install this into Apps Code, then install the app with Add User App. Select the troublesome contact sensors and hit Done. Open a new Logs page. Then open the two contact sensors, and post the logs here.
definition(
name: "Test Contacts",
namespace: "hubitat",
author: "Bruce Ravenel",
description: "Rule",
category: "Convenience",
iconUrl: "",
iconX2Url: ""
preferences {
section {
input "contacts", "capability.contactSensor", title: "Select contact sensors", multiple: true
def updated() {
unsubscribe()
initialize()
def installed() {
initialize()
def initialize() {
subscribe(contacts, "contact.open", handler)
def handler(evt) {
log.debug "Contact open: ($evt.displayName), device: $evt.device"
The 3 unit NOTworking fine are Hank HKZW-DWS01, THEY NEVER GO TO DELAY INTRUSION.
I just found somthing about this item, but I do not know if it has to do with my problem.
Hank HKZW-DWS01 Door/Window Sensor (aka Monoprice 24259)
I want to see your device list for the good one.
app:17002020-12-22 07:55:23.923 pm infoDelaying off for 15 minutes
app:16372020-12-22 07:55:23.900 pm infoDelaying off for 15 minutes
app:19092020-12-22 07:55:23.886 pm infoDelaying off for 20 minutes
app:16342020-12-22 07:55:23.866 pm infoDelaying off for 15 minutes
app:19102020-12-22 07:55:23.851 pm infoDelaying off for 10 minutes
dev:17062020-12-22 07:55:23.799 pm infomZone-Any is inactive
app:17002020-12-22 07:55:23.790 pm infoMotion inactive mZone-1st Floor
app:16372020-12-22 07:55:23.773 pm infoMotion inactive mZone-1st Floor
app:19092020-12-22 07:55:23.770 pm infoMotion inactive mZone-1st Floor
app:19102020-12-22 07:55:23.767 pm infoMotion inactive mZone-1st Floor
app:16342020-12-22 07:55:23.763 pm infoMotion inactive mZone-1st Floor
dev:13612020-12-22 07:55:23.744 pm infomZone-Comun areas is inactive
dev:13632020-12-22 07:55:23.727 pm infomZone-1st Floor is inactive
app:16032020-12-22 07:55:18.783 pm infoDelaying off for 5 minutes
app:16032020-12-22 07:55:18.651 pm infoMotion inactive Living room
dev:13132020-12-22 07:55:18.622 pm infoLiving room is inactive
dev:16142020-12-22 07:54:55.536 pm infoVirtual GATE is open
dev:7712020-12-22 07:54:50.837 pm infoDoorbell/ Street Door was turned off
app:10612020-12-22 07:54:50.702 pm infoAction: Wait for condition: Gate, Doorbell/ Street Door all closed FALSE --> timeout: 0:15:00
app:10612020-12-22 07:54:50.665 pm infoAction: IF (Mode in 1Day, 2Evening, 3Dinner(T) [TRUE]) THEN
app:10612020-12-22 07:54:50.623 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) Triggered
app:10612020-12-22 07:54:50.611 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) : Gate contact open
app:18782020-12-22 07:54:50.536 pm errorgroovy.lang.MissingMethodException: No signature of method: com.hubitat.hub.executor.AppExecutor.sleep() is applicable for argument types: (null) values: [null] Possible solutions: sleep(long), sleep(long, groovy.lang.Closure), grep(), grep(java.lang.Object), dump(), every() on line 1070 (priorityHandler)
app:18752020-12-22 07:54:50.531 pm debugContact is in open state
app:18782020-12-22 07:54:50.507 pm debugIn checkVol - volume: 60
app:18782020-12-22 07:54:50.504 pm debugIn checkVol...
app:18782020-12-22 07:54:50.489 pm debugIn checkTime - timeBetween: true
app:18782020-12-22 07:54:50.487 pm debugIn checkTime - null - null
dev:16142020-12-22 07:54:50.474 pm infoVirtual GATE is opening
app:18782020-12-22 07:54:50.465 pm debugIn letsTalk...
dev:16202020-12-22 07:54:50.440 pm debugpContactDevice2 - has null Characters
dev:16202020-12-22 07:54:50.427 pm debugpContactDevice1 - has 561 Characters
Gate | open | |
En trance Door | open | |
Pa tioDoor | open | |
Ter race door | open |
app:18782020-12-22 07:54:50.375 pm debugIn priorityHandler - Building Table Wrong Contact with Ter race door count: 4
app:18782020-12-22 07:54:50.363 pm debugIn priorityHandler - Building Table Wrong Contact with Pa tioDoor count: 3
app:18752020-12-22 07:54:50.355 pm debugContact is in open state
app:18782020-12-22 07:54:50.352 pm debugIn priorityHandler - Building Table Wrong Contact with En trance Door count: 2
app:18782020-12-22 07:54:50.349 pm debugIn priorityHandler - Building Table Wrong Contact with Gate count: 1
app:14122020-12-22 07:54:50.347 pm infoTurn Off Doorbell/ Street Door when Gate, Doorbell/ Street Door Opened Turn Off
app:18782020-12-22 07:54:50.317 pm debugIn priorityHandler - contacts
app:18782020-12-22 07:54:50.314 pm debugIn priorityHandler
dev:7702020-12-22 07:54:50.279 pm infoGate contact is open
app:15702020-12-22 07:54:43.297 pm infoAction: Wait for event: Pa tioDoor closed --> timeout: 0:08:00
app:15702020-12-22 07:54:43.273 pm infoAction: END-IF
dev:3402020-12-22 07:54:43.267 pm infoEwelink Sw1 (Ch4 Patio) is on
app:15702020-12-22 07:54:43.260 pm infoAction: On: Ewelink Sw1 (Ch4 Patio)
app:15702020-12-22 07:54:43.257 pm infoAction: IF (Time between Sunset-30 minutes and Sunrise+30 minutes(T) [TRUE]) THEN
app:15702020-12-22 07:54:43.217 pm infoAction: IF (NOT Mode is 7Friends(T) [TRUE]) THEN
app:6112020-12-22 07:54:43.196 pm infoAction: Wait for condition: En trance Door, Pa tioDoor, Ter race door all closed FALSE --> timeout: 0:15:00
app:15702020-12-22 07:54:43.178 pm infoRule: Patio Doors open->ON & wait until closes in next 8min(OFF after 20 min) Triggered
app:15702020-12-22 07:54:43.167 pm infoRule: Patio Doors open->ON & wait until closes in next 8min(OFF after 20 min): Pa tioDoor contact open
app:6112020-12-22 07:54:43.163 pm infoAction: IF (Mode in 1Day, 2Evening, 3Dinner(T) [TRUE]) THEN
app:18782020-12-22 07:54:43.099 pm errorgroovy.lang.MissingMethodException: No signature of method: com.hubitat.hub.executor.AppExecutor.sleep() is applicable for argument types: (null) values: [null] Possible solutions: sleep(long), sleep(long, groovy.lang.Closure), grep(), grep(java.lang.Object), dump(), every() on line 1070 (priorityHandler)
app:6112020-12-22 07:54:43.087 pm infoRule: mosquito HOME Doors open-> 7-20 minutes->Virtual sw Mosquito Doors checker (repeat 3-2 times): Pa tioDoor contact open
app:6112020-12-22 07:54:43.065 pm infoRule: mosquito HOME Doors open-> 7-20 minutes->Virtual sw Mosquito Doors checker (repeat 3-2 times) Triggered
app:18782020-12-22 07:54:43.060 pm debugIn checkVol - volume: 60
app:18782020-12-22 07:54:43.048 pm debugIn checkVol...
dev:3402020-12-22 07:54:43.045 pm infoEwelink Sw1 (Ch4 Patio) was turned on
app:18782020-12-22 07:54:43.042 pm debugIn checkTime - timeBetween: true
app:6112020-12-22 07:54:43.031 pm infoRule: mosquito HOME Doors open-> 7-20 minutes->Virtual sw Mosquito Doors checker (repeat 3-2 times): Pa tioDoor contact open
app:18782020-12-22 07:54:43.028 pm debugIn checkTime - null - null
app:18782020-12-22 07:54:43.023 pm debugIn letsTalk...
dev:16202020-12-22 07:54:43.015 pm debugpContactDevice2 - has null Characters
dev:16202020-12-22 07:54:42.952 pm debugpContactDevice1 - has 464 Characters
app:18782020-12-22 07:54:42.924 pm debugIn priorityHandler - Building Table Wrong Contact with Ter race door count: 3
app:18782020-12-22 07:54:42.919 pm debugIn priorityHandler - Building Table Wrong Contact with Pa tioDoor count: 2
app:18782020-12-22 07:54:42.895 pm debugIn priorityHandler - Building Table Wrong Contact with En trance Door count: 1
app:18782020-12-22 07:54:42.888 pm debugIn priorityHandler - contacts
app:18782020-12-22 07:54:42.880 pm debugIn priorityHandler
dev:3972020-12-22 07:54:42.842 pm infoPa tioDoor was opened
app:10612020-12-22 07:54:35.845 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) Exited
app:10612020-12-22 07:54:35.810 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) : Action Repetition stopped
app:10612020-12-22 07:54:35.783 pm infoAction: Stop Repeating Actions
app:10612020-12-22 07:54:35.775 pm infoAction: ELSE (do actions)
app:10612020-12-22 07:54:35.772 pm infoAction: On: V.Sw FRONT/STREET Doors checker (skipped)
app:10612020-12-22 07:54:35.767 pm infoAction: IF (Gate, Doorbell/ Street Door any open(F) [FALSE]) THEN (skipping)
app:10612020-12-22 07:54:35.663 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) : Repeating Actions 5 times
app:10612020-12-22 07:54:35.532 pm infoAction: Wait for condition: Gate, Doorbell/ Street Door all closed TRUE --> timeout: 0:15:00 (not waiting)
app:6112020-12-22 07:54:35.529 pm infoAction: Wait for condition: En trance Door, Pa tioDoor, Ter race door all closed FALSE --> timeout: 0:15:00
dev:3232020-12-22 07:54:35.526 pm infoEntrance Switch 1 switch is on
app:6112020-12-22 07:54:35.481 pm infoAction: IF (Mode in 1Day, 2Evening, 3Dinner(T) [TRUE]) THEN
app:10612020-12-22 07:54:35.478 pm infoAction: IF (Mode in 1Day, 2Evening, 3Dinner(T) [TRUE]) THEN
app:10612020-12-22 07:54:35.345 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) Triggered
app:10612020-12-22 07:54:35.339 pm infoRule: any FRONT/STREET Doors open-> 15/60m -5/30m->Virtual sw FRONT/STREET Doors checker (repeat 3-2 times) : En trance Door contact open
app:18782020-12-22 07:54:35.325 pm errorgroovy.lang.MissingMethodException: No signature of method: com.hubitat.hub.executor.AppExecutor.sleep() is applicable for argument types: (null) values: [null] Possible solutions: sleep(long), sleep(long, groovy.lang.Closure), grep(), grep(java.lang.Object), dump(), every() on line 1070 (priorityHandler)
app:6112020-12-22 07:54:35.308 pm infoRule: mosquito HOME Doors open-> 7-20 minutes->Virtual sw Mosquito Doors checker (repeat 3-2 times) Triggered
app:6112020-12-22 07:54:35.286 pm infoRule: mosquito HOME Doors open-> 7-20 minutes->Virtual sw Mosquito Doors checker (repeat 3-2 times): En trance Door contact open
app:18782020-12-22 07:54:35.278 pm debugIn checkVol - volume: 60
app:18782020-12-22 07:54:35.273 pm debugIn checkVol...
app:18782020-12-22 07:54:35.269 pm debugIn checkTime - timeBetween: true
app:18782020-12-22 07:54:35.264 pm debugIn checkTime - null - null
app:18782020-12-22 07:54:35.259 pm debugIn letsTalk...
dev:16202020-12-22 07:54:35.244 pm debugpContactDevice2 - has null Characters
app:22352020-12-22 07:54:35.206 pm debugContact open: (En trance Door), device: En trance Door
dev:16202020-12-22 07:54:35.203 pm debugpContactDevice1 - has 361 Characters
app:18782020-12-22 07:54:35.123 pm debugIn priorityHandler - Building Table Wrong Contact with Ter race door count: 2
app:18782020-12-22 07:54:35.090 pm debugIn priorityHandler - Building Table Wrong Contact with En trance Door count: 1
app:10652020-12-22 07:54:35.033 pm infoTurn On Entrance Switch 1 when En trance Door Opened Turn On
app:18782020-12-22 07:54:35.029 pm debugIn priorityHandler - contacts
app:18782020-12-22 07:54:35.027 pm debugIn priorityHandler
app:16372020-12-22 07:54:31.049 pm infoNot turning on, already on
app:17002020-12-22 07:54:31.047 pm infoNot turning on, already on
app:19102020-12-22 07:54:31.029 pm infoNot turning on, already on
app:19092020-12-22 07:54:31.023 pm infoNot turning on, already on
app:16342020-12-22 07:54:31.019 pm infoNot turning on, already on
app:17002020-12-22 07:54:31.006 pm infoMotion active mZone-1st Floor
app:19092020-12-22 07:54:30.997 pm infoMotion active mZone-1st Floor
app:19102020-12-22 07:54:30.994 pm infoMotion active mZone-1st Floor
app:16032020-12-22 07:54:30.992 pm infoNot turning on, already on
app:16372020-12-22 07:54:30.989 pm infoMotion active mZone-1st Floor
app:16342020-12-22 07:54:30.978 pm infoMotion active mZone-1st Floor
app:16032020-12-22 07:54:30.953 pm infoMotion active Living room
dev:17062020-12-22 07:54:30.951 pm infomZone-Any is active
dev:13612020-12-22 07:54:30.944 pm infomZone-Comun areas is active
dev:13632020-12-22 07:54:30.940 pm infomZone-1st Floor is active
dev:13132020-12-22 07:54:30.906 pm infoLiving room is active
Not like that. Use a screenshot. Isolate the logs to Test Contacts only.
I only want to see what the app logs.
HERE IS THE LOG JUST AFTER OPENIGNG THE NOT WORKING FINE HANK CONTACT SENSOR . Sorry for capital letters The working fine one is the GATE almost all the way to the top of the log.
the problem is that all 3 hank contact sensor I have, they DO NOT go to delay intrusion, they all go to instant intrusion.
My theory proven wrong. I don't know why these are failing.
Ok, I will buy a difente contact sensor from other brand, I hope this way I will fix my problems. Thanks so much for your dedication and time
Today I got new Ring Contact sensor, but same problem as with my Hank HKZW-DWS01, THEY WILL NOT GO TO DELAY INTRUSION NIGHTThey will go into intrusion instantly without any delay. No mather what I do.
As I have reported before I have a conact sensor wire conected to a MIMO2+ named GATE, and when it is activated, it dose go right into intrusion-night-DELAY with no problems.
I am adding my configuration, logs and notifications to show when it dose NOT GO intio intrusion-night-DELAY when using my brand new sensor, and when it goes intio intrusion-night-DELAY using a conact sensor wire conected to a MIMO2+
Same issue on my side: Armed-Home is set with a 30s delay on the front door, it worked for some time and now it doesn't. The log clearly shows the alarm intrusion is triggered at the time the door is opened.
You will have to provide all of the details: screenshots, logs, etc. to show exactly what is going on.
