the reason there is a second 0:00:30 (cancel) is becuase i can't work out how to remove that without rebuilding whole action - I had no choice but to insert an action when i build it as i chose wrong option.
When you select (cancel) against an action all you are doing is giving the action the ability TO BE cancelled.
To make the action be cancelled you have to tell the rule to cancel those actions.
Here is one for a WC light.
The Private Boolean stops the rule being continually evaluated while motion is active.
You can ignore this if you wish but this gives an idea of what you need to do.
thank you. i am working today and my lights and heater are turning off constantly - so much appreciated.
does this look a bit better? it would seem tho that right at the 15 min mark, i'd have to have motion active or it will still turn off. how can i make it check anytime during the 15 min to cancel action?
Yes, it's better, but your IF will never run (only the ELSE) because your trigger is motion inactive, so "motion active" will always evaluate to false when the rule actions run (which only happens when the trigger event fires). You could switch your trigger to "changed" instead of "inactive," move your "Delay" to the ELSE, and then your rule would probably do what you want.
That being said, if this is all you want, Hubitat Simple Lighting and Motion Lighting can both do this for you with a lot less work. (I know they say "lighting," but they work with any kind of switch device.) If you want to use Rule Machine, I'd suggest reading the Rule 4.0 docs first, which contain an example almost exactly like what you're trying to do.
right. i guess i got confused as the cancel delayed action is above. so the dealyed 01:00 (cancel) must be called within in that time period if the cancel delayed action becomes true?
This rule does the same as your old one--either should work. A delay on one action is the same as a delay and then an action as long as you don't have anything after it (then they're different: a delay action will pause the script there, while a delay on an action delays that action but continues the script).
You're also missing an END-IF. It will silently imply one for you, but it's good practice.
