How do I input the temperature degree sign in a message/notification that is sent to my mobile phone?
You mean one of these? °
Yes, °.
Same way you made that one?
I use Apple Mac, so I use CtrlCmdSpacebar and type in degree. That gives me this.
If using PC, not sure of the steps to get to the emoticons.
@Slate: Well, I did a copy and paste from your post! ![]()
How would I insert the ° symbol using my iPhone keyboard, or my pc?
Either! Or use the copy paste you used here if you are lazy.
I agree with @Slate.
Might as well just copy/paste from this thread.
Or you can copy/paste a degree symbol from any other source of text.
You can also search for the “Windows alt code” for the degree symbol. By entering “Alt +” then the relevant string of numbers, you can enter many different symbols with your keyboard while using Windows.
On the iPad’s Magic Keyboard, the ˚ can be displayed with « option »-k.
Or, on the iPad, hold down the zero key and it will give the ° option.
Also, on a PC keyboard, you can hold down ALT and type "248" on the keypad, and it will create an °.
Oh, that’s good to know! Thanks!
